Question about Bloomfield 8571 Coffee Maker
Will not fill pot
I have Bloomfield 8572 I think this is an old model of 8571. The pot fills about 1/2 even after I adjust the the fill adjust in front of the machine.
It only changes the level a very little bit. Is there a valve or something
I can change to correct this problem?
    Problem Solver:
  • 11 Answers
I'd also check to see if there is a filter or valve attached to the supply line as these might be closed or clogged.
Posted on May 20, 2013
  • 25 Answers
Most likely you have some lime-scale build-up. When you brew a pot, it only brews the same amount of water that it takes in. When the inlet is restricted with scale, not enough water is let in for a full pot. You've adjusted the timer, so when you clear the inlet, you should set it back down so you don't overflow the pot.
It also could be just something cought in the inlet orifice (result is the same). Either way, start where the water is connected to the machine and go from there. Sorry I can't be more specific, scale is an elusive devil.
In the future, try using soft water.
Good luck
Posted on Mar 10, 2008
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Why is my bloomfield 8571 leaking?
Remove the top panel and check for scale on the liquid level probe. Remember to unplug the machine first.
Jul 15, 2014 | Bloomfield 8572 Coffee Maker
How do I drain a bloomfield 8571?
I would remove the big fat rubber elbow from the tank going to the fill basin...and turn the brewer upside down in my sink. This is how I drained about ten thousand of them (not joking about the ten thousand). But it depends on what you are doing. Did you want to delime it? Did you pour coffee in it by mistake instead of water?....What ever the reason be sure you let it dry out good. Coffee machines are use to flooding, spraying internally, leaking and they are built to shut down breakers. If you are pulling the tank or just removing the top, you may want to leave the water in to see how much water vs lime and sediment fill the tank. Depends on where you live. Enjoy.
May 20, 2014 | Bloomfield 8571 Coffee Maker
Coffee only pours a half a pot at a time when I
Check / set the timer for a longer brew cycle.
Mar 10, 2010 | Bloomfield 8572 Coffee Maker
Bloomfield 8540-When doing pour over, ready light never comes on and water keeps heating. Unit puts out alot of steam. Unit will produce a hot pot of coffee.
the thermostat could be faulty or out of adjustment. To adjust it (on my 8572) unplug it, remove the top, there is a box (black on mine) with four wires and a copper tube which goes into the tank (temperature sensor) which has a half enclosed tube sticking out of it with a small screw inside. Remove the small rubber hose from the top of the tank and place a thermometer into the tank through the hole. Turn the sdjusting screw counter-clockwise until it stops (check the +/- signs to be sure) and plug it back in to see if it will shut off before boiling...***MAKE SURE NO WIRES ARE SHORTED BY THE THERMOMETER AND DO NOT REACH INTO UNIT WHILE IT IS PLUGGED IN DUE TO SHOCK/FIRE HAZZARD*** if it stops heating before boiling, turn the adjusting screw clockwise a bit at a time until it shuts off at 205 degrees faranheit and reassemble the unit. If not replace the thermostat.
Nov 13, 2009 | Bloomfield 8571 Coffee Maker
Is there a way to adjust thee fill level?
remove the round metal piece on the front ... behind it is a dial the adjusts the time of the brew .... it's very touchy so be ready w/an extra glass pot if it overfills .... good luck
Jul 31, 2009 | Bloomfield 8572 Coffee Maker
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Instructions for bloomfield 8752 same as 8571?
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
Oct 23, 2008 | Bloomfield 8571 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Bloomfield 8571 Coffee Maker Logo
330 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
Kelley Hopper
frankecoffee
Level 1 Expert
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
