Question about Dell A920 InkJet Printer
Dell A920 Problem
When I switch the printer on or off, or start up the PC, it seems to get stuck at start up. The heads move, and there is the cur-clunk-clunk noise, like it does when you first turn it on, but it can do this for 4 or 5 minutes continuously. Unplugging the power makes no difference. The printer icon on the task bar shows a red cross through it when this is happening. Once this stops it prints normally.
I have uninstalled it, reinstalled everything, tried plugging into a different USB port, but it is still the same.
I am running Windows XP, SP2, with all the relevant updates.
Thanks
Debbie
    Problem Solver:
  • 8 Answers
Servicing problam
Posted on Mar 16, 2008
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 11, 2011 | Dell A920 InkJet Printer
    My dell A929 printer light keeps flashing.what could be the problem?
    Check if you have enough ink. Where does the printer head move to when you open the compartment(that if it has a head indicator).
    flashing in this instance idicate that there is a problem with your ink.
    Jul 04, 2010 | Dell A920 InkJet Printer
    Printer only prints half of page
    My printer does this when the paper isn't seated properly and/or that paper guide isn't set correctly. If this all seems OK, then try a head clean. You should be able to do this from the printer options in Windows.
    Dec 13, 2009 | Dell A920 InkJet Printer
    How do I get my Dell A920 to work on my new HP
    Uninstall the printer drivers.
    Download and install the latset and appropriate driver package from Dell.
    Oct 25, 2009 | Dell 922 All-In-One InkJet Printer
    Dell a920 network problem
    I will assume you have the Printer connected directly to a PC via the USB printer cable on our network.
    a. Start - Run - Control - Ok
    b. Open 'Printers and Faxes"
    c. Open "Dell A920"
    d. Print "Test Page" to assure the printer is working and connected.
    e. With the "Dell A920" properties open - find the tab for Sharing.
    f. Now select Share the Printer and name it.
    At each Workstation you will need do steps a-b, and add the printer. Select browse network when adding the printer and find the Workstation with the shared printer.
    If your Firewall on each Workstation is blocking "Print and File Share" you will need to change the settings to allow this procedure through.
    Here is a link that may help further.
    http://www.smartcomputing.com/Editorial/article.asp?article=articles/webonly/techsupport/73w10/73w10.asp&guid=
    Hope this helps.......
    God Bless.......
    Jul 28, 2009 | Dell A920 InkJet Printer
    Hoirizontal white lines and poor quality in black and white print on dell a920 inkjet printer
    If you are sure your ink cartridge is not empty, it may be worth running the head cleaner a few times then print a test page.
    Worth a try for nothing.
    Good luck.
    Feb 23, 2009 | Dell A920 InkJet Printer
    Copier/scanner not working
    have u installed all the software from the cd? here is the manual http://support.euro.dell.com/support/edocs/systems/a920/en/index.htm
    Jul 13, 2008 | Dell A920 InkJet Printer
    No print
    replace cart. first with original.
    Dec 18, 2007 | Dell A920 InkJet Printer
    Printer Stuck
    Rano, The power cord is connected at the back of the printer with a rectangular connection, make sure the inner cables in the connectors aren't burned, I had the same problem and I replaced a burned cable and now its working fine!
    Apr 16, 2007 | Dell A920 InkJet Printer
    Dell A920 InkJet Printer Logo
    51 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
