Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
Rca rear projection hdtv lost color convergence
Convergence just went poof. now all colors are separated after hitting convergence on menu only got skinny lines of separate color at top of screen above pictue then convergece no longe an option on the menu
  • 1 more comment
  • jlosey Mar 27, 2008
    Same.
  • jessikka Nov 08, 2008
    i have red blue and green 3 d tracers
  • joshpaulc Dec 16, 2008
    the screen picture is bowed in and the red, blue and yellow are seperated showing three of everything, will not auto correct. How do I manually fix?
  • RCA Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
rca rear projection hdtv lost color convergence - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
I have a 52 rca rear projection was watching tv and went black after a few minutes it turned back on from the power button and i have color lines on the screen and pic is ditorded almost like in a bubble....
Go to Menu ,then Setup look and see if you have Convergence on the Menu ? If you do not see convergence in the Menu then you have a Blowed Fuse FL231 on the Deflection Board.
Let me know what you have listed in the Menu.Problem is not in the Tubes R/G/B.
Feb 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The color on the set is separated and bowed.
When you go to menu then setup Do you see Convergence in the menu?
Nov 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurry picture colors are separated and there is a curved picture.
Bad convergence. Check menu and try auto convergence if that don't work then the board is bad
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Color ghost
Sounds like your convergence is off. Go into your menu and try setting your convergence. If you can not move any of the colors you need to have your convergecnce amplifers replaced
Apr 08, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color convergence
Resolder or replace convergence IC's stk ###-###
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
Jun 30, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
219 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
