Question about Cameras
How to unlock a Pentax Optio W10
My Optio W10 seems to randomly lock itself so that I cannot access the menu options to change any of the camera settings. I can still take pictures and view the pictures I've taken. I can also turn my flash on/off, change the drive mode, and the focus mode (the three buttons surrounding the OK button), however when I hit the Mode or Menu buttons, a yellow padlock icon is displayed on the left of the screen.
Any ideas to unlock it?
  • scrappystace Feb 27, 2009
    My phone somehow got locked. It is stuck in green mode (whatever that is). When I press the mode button to try to get in the menu, I get a yellow padlock. No matter what I do I can't unlock it.
Press menu and the trash / delete buttons at the same time. Hold for 3 seconds until it beeps. WALA unlocked:):)
Posted on May 02, 2008
Hit mode then trash can
Posted on May 04, 2008
My Pentax Optio W10 camera takes some out of focus photos. What do I do to solve this problem?
Your camera has the option for manual focus. This option allows you to focus the camera to capture what you want, rather than the auto-focus feature.
This will be indicated by a MF in the top center of your camera screen. You should be able to change this by finding record mode and changing your AF settings. Change your MF to the [ ] option and you should be on auto-focus settings.
Hope this helps.
Chadlnrd
Feb 28, 2011 | Pentax Optio W10 Digital Camera
How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 22, 2010 | Pentax Optio W10 Digital Camera
Card locked
Remove your card from the camera.
Unlock your card shown in the upper figure.
May 02, 2010 | Pentax Optio W10 Digital Camera
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
My Pentax Optio S5z locks itself somehow. Before it usually unlocked on it's own also. Now it is stuck on LOCK and I am not able to delete pictures, or use the MENU or MODE buttons. I am able to take...
Is the slide switch on the side of the card in the unlocked position? If so, try this...remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 28, 2009 | Pentax Optio S5z Digital Camera
How to unlock card in pentax optio w10
Move the slide switch on the side of the card.
Sep 26, 2009 | Pentax Optio W10 Digital Camera
How do you reformat the camera
I can't send you the actual PDF of page 160 of the Optio W10 manual thru here, but here is the link to that manual on the Pentax web site: http://www.pentaximaging.com/support/manuals-and-literature/
Sep 12, 2009 | Pentax Optio W10 Digital Camera
Unlock Pentax Optio S5z
I had the same problem with the exact same camera (Pentax Optio S5Z) that happened the same way. I searched everywhere on the web and finally found this post that didn't have a solid solution. So I started experimenting with different button combinations and finally figured it out.
Hold the OK button while turning on the camera. The screen should indicate that it is in audio record mode. Now press the Menu button and use the navigation keys to find and execute the system reset option.
After turning it off and back on it should function normally.
Mar 16, 2008 | Pentax Optio S5z Digital Camera
Menu Locked
While in capture mode, hit the green (delete) button.
You can change modes from here. :)
Jan 31, 2008 | Pentax Optio W10 Digital Camera
Card locked on my optio w10
Check your manual for the image protect function. or simply reformat in camera.
Jun 14, 2007 | Pentax Optio W10 Digital Camera
Cameras Logo
1,641 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
