Looking for a "senior-friendly" universal
Looking for a "senior-friendly" universal remote for Vizio HD LCD tv. Must have button to change picture formats (wide, etc.)
My problem, stated above, has nothing to do with Projection screen tv. I still have not solved the problem stated above!
Posted on Mar 09, 2008
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I am looking for the code for my Visio Sound Bar to program into my Dish Network remote to the AUX button. Has anyone talked with Visio Support to get this code? Thanks.
ronwright22
I have provided a link for you to Vizio's Website. The information below is for a VSB210WS sound bar. I would go to this link and research your model number and look for the code. You may try the code on this screen to see if it will work. I have also provided a link with instructions on programming your DISH remote to other components.
Vizio Website:
http://www.vizio.com/vsb210ws.html
This is the VSB210WS sound bar.
Programming a Universal Remote to operate the HD Sound Bar System If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program a device button with code 31517. This will map the Universal Remote button to operate the HD Sound Bar System as follows: Pictured at right is the VIZIO VUR8P Universal Learning remote.
Ray Calo
DISH Network
Nov 09, 2010 | DISH Network IR Remote Control
White flickering line across top of tv with non HD channels
It appears that when you go back to normal tv from hdtv you are able to see the overscan area. Change the aspect of your image with the appropriate button on your Vizio remote and or cable remote. Apparently the button that changes the aspect on the Vizio remote is the wide button. The cable remotes will usually have hd zoom (#), aspect or format.
Sep 28, 2010 | Vizio L32 32 in. LCD HDTV
I have a Vizio LCD TV and lost the remote that came with the TV. I have a one for all universal remote, its a URC-4640BOO . I am looking for a code to program the TV
see the vizio website, click on the "support" tab and look in the FAQ regarding programming non-Vizio remotes for Vizio products (#6 in FAQ list), they have all 3, 4 and 5 digit codes there
www.vizio.com/support
Dec 11, 2009 | Vizio VW37L 37 in. LCD TV
REMOTE SRU9600 TO CONTROL A 52" VIZIO HD LCD
You may have to try a different universal remote control.
Nov 05, 2017 | Philips SRU9600 LCD Touchscreen Remote...
Remote
dollar store has a cheap 1$ remote with auto search on it,Make sure it has the paper work in it you need a instruction book (paper),does not work on the magnavox TB100MW9 hd box, but it is a 4-in one and works with my vizio,sony,samsung,and yamaha equipment, any auto search remote should help, in the store you can read on some universal remotes list of what they support.
Dec 26, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Emerson tv remote code
I have ask some help from our friends and they also have problems regarding this type of TV... But try this one
Quotes from friends:
1. "The universal remote that came with my Motorola HD cable box worked fine"
2. chat sessions
3. Chat session find jcut92
My quote:
Ask the vendor for a code, if they don't give you return the TV , it lacks technical support... Believe me or else face more problems in the days to come.
I'm sorry, there's lo luck... Fixya me instead...
Feb 05, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
