Rewiring an old pioneer stereo.the radio was installed where it powers without the ignition being on.the battery was draining. figured it had to be the radio. pulled radio. the red power(acc wire) was connected to yellow( battery) which connected to a hot terminal on the fuse panal. when i rewire, do i need to use the yellow wire, or can i just tie it off and connect the red to a fuse?
  • 86scirocco Mar 07, 2008
    thanks. truely appreciated. i've tried everything possible to fix my battery drainage problem.( coil alternator, battery, regrounding). your advise seems to have fixed to problem..
  • 46 Answers
Hello...if you are sure that the red wire is acc it should be connected to the acc connection of the ignitionkey.or maybe the lighter positive...and the other to the battery"always 13.8 v"...then the memory will function properly of the radio and you will not drain your battery...please tell me what happens...good luck ...Ron
Posted on Mar 07, 2008
Why wont radio turn off?
This often happens when people diy aftermarket stereo installation. Aftermarket stereos require both accessory and hot wires, while many auto wiring harnesses provide only hot leads. You must add an accessory wire from the fuse box to the stereo to prevent the battery from draining. If you are up to doing that, I can provide instructions.
Jul 21, 2017 | Jeep Cars & Trucks
Trying to install the fh-x700bt into my 2005 gmc envoy. I am using the GM1590AB and the GM05B + Red Wire. I was able to connect all of the speaker wires correctly. I'm having trouble beyond that. The red...
The amplifier is in the passenger side rear quarter panel.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jun 29, 2014 | Pioneer FH-X700BT
I have a 98 ford winstar I'm installing a pioneer
You'll need to check that you have the yellow wire connected to constant battery, power from battery, not thru the ignition switch. The yellow wire is the power wire for the clock and radio presets.
May 13, 2010 | Car Audio & Video
1995 toyota tacoma stereo installation - yellow 12v wire and red power wire - where do I connect these? Original radio was removed by previous owner. Factory connector cut but I have all wire showing. I...
Yellow (module memory) 12v wire needs constant power... any "always on" circuit in your car. Red power wire can be connected to your AUX fuse on your fuse panel.... or to the red power lead that powers your original radio.
Oct 12, 2009 | Pioneer CDJ-1000 CD Player
Installed pioneer cd player/radio in '01 tracker. got hot
some stereos don´t support the original wired of the car and you need to rewired the speakers
Jul 12, 2009 | Pioneer DEH-P4000UB CD Player
1996 chevy 1500
with the ignition in the "off" position get a test light and touch one wire at a time while cycling the ignition switch to the "on" position, When you see that the test light goes off when the ignition switch is in the off position then you found the hot wire, make sure you dont hook it up to the "alway hot " wire or you might drain the battery hope this helps.
Oct 18, 2008 | 1996 Chevrolet Express
I tried to install a radio but im not getting any power to the stereo when I turn the car on to acc.
ok did you hook up red to ignition and yellow to constant power?
check all the fuses car and back of head unit
if worse comes to it connect red and yellow to geather and send it straight to the positive on the battery with a fuse but u will have to turn the radio on and off by your self not the ignition
Jul 04, 2008 | Pioneer Car Audio & Video
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Mar 13, 2008 | Pioneer DEH-P6800MP CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
108 people viewed this question
 Grubhead
Grubhead
