Question about Estate TAWS800JQ Top Load Washer
Leaking Washer How do I change a drain pump?
  • 5,911 Answers
Here ya go. I hope this information helps you.
Read the instructions thoroughly BEFORE attempting. This is a simple repair that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. It is advisable at this point to drain the residual water from the wash tub. This will save you a lot of clean up time later. Here’s a helpful HINT: If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall. Connect the shop vac to the end of the drain line and pull a vacuum on it. This will quickly drain the residual water and leave you with little to no mess. If you do not own a shop vac, remove the lower hose from the pump and place a pan or a bunch of old towels under it & allow to drain.
8. Remove the water pump by removing the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and remove both hoses. HINT: This is a good time to inspect the drain lines for any debris that may have gotten lodged in the lines.
9. Install new water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly on the motor shaft. Make sure you re-install the retaining clips correctly. Insert the keyed end first, then turn and snap them in place over the pump.
10. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
11. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
12. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
13. Reinstall console.
NOTE: This water pump IS NOT serviceable. Meaning, it does not come apart. You can, at times, manage to dislodge items that have become stuck in the pump by slowly rotating the shaft backwards (with the pump removed from the washer) while pulling the object free. Sometimes this works, but sometimes the seal becomes damaged. Panty hose, underwear and the under wire from bras are notorious for getting stuck in these pumps. HINT: It is STRONGLY recommended that you use small nylon garment bags while washing some of your smaller items like this.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. A new washer pump should cost about $40.
Posted on Mar 07, 2008
My LG WM2455 has water leaking from lower front near the front access door. I have checked the catch basin and drained the tube but still get leakage after the next load. What could the problem be?
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Check the condition of the drain hose that connects the tub to the pump.
Aug 25, 2014 | LG WM2455 Front Load Washer
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
My whirlpool ultimate care 2 washer was leaking underneath while running, I removed the back panel and dropped the drain hose to the floor and extended it out the door to the yard and while filling the tub...
The drain hose must be at least level with the top of the actual tub in the washer. The water pump is only bad if it is leaking. If it is leaking from the front you either have a cracked outer tub, but it sounds like your water pump, easy to change out just get the model # and order it through an appliance parts distributor. The cost is about 40 to 50 bucks. good luck!
Aug 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
It is leaking from the bottom during the wash cycle. What is going on?
If you mean its leaking anytime you have water in the drum,the first thing to check is the drain hose connection at the back of the washer,You'll want to do this with the washer pulled out,(don't let the drain hose drop below the water level or you'll have a mess)If its not leaking there you should be able to look under the washer & see which connection it is(usually the inlet to the pump) Might be as simple as tightening the hose clamps.Hope this helps
Jan 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
May 10, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . parts@appliancedesk.com ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
Nov 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Estate TAWS800JQ Top Load Washer Logo
60 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
