Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Dead set When power button is pressed the red light on the front of the set blinks three or four times and then stays on. A fant squell can be heard when power button is pressed. B+ on the collector of the horiz. output transistor is 75 volts when power button is pressed but drops out immediately. I have checked filter in power supply and have found none that are bad. Any ideas?
  • 1 more comment
  • uncle red Mar 08, 2008
    The high voltage does not come up so the tubes do not arch. I don't have a diagram for this set so i am kind of shooting in the dark. When the power button is pressed i hear a faint squell. I think the horiz. freq. is off preventing the set from powering up.
  • hancho Mar 13, 2008
    It's currently dead. Turns on with bright screen & scan (?) lines, fades out, then the bulbs flash and it shuts itself off.
  • djmarvin Mar 19, 2008
    blinks three or four times and then stays on. A high pitch squeal can be
    heard when power button is pressed. Problem started after a power surge in the house. TV was on a surge strip and everything else is working fine. Is this worth having repaired or am i better off buying a new tv.
  • 103 Answers
These sets had a serious crt problem.Check and see if there is any arching on the tubes or tube sockets.
Posted on Mar 07, 2008
I need code for curtis tv and proper direction how to install and retain code
Hello
Three digit universal remote for Curtis TV are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote code for Curtis are:-
0031 0105 0130
........................... 0004 0009 0000 0049
........................... 0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NB:- Please turn OFF and switch it ON with its front panel power control switch each time before trying an other code. OK.
Mar 14, 2011 | Televison & Video
Need code for toshiba flat screen tv
Hello
Three digit universal remote code for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit universal remote codes for Toshiba are:-
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
NB: Switch OFF and switch ON your TV, with its front panel power control switch each time before trying an other code.
Direct Code Entry
Mar 13, 2011 | Toshiba Televison & Video
Need remote code for orion tv
Hello
Three digit universal remote code for Orion are:
035/ 121/ 135
Four digit universal remote code for Orion Tv are:
0121 0135 0035
Direct Code Entry
NB: Switch OFF and switch ON your TV, with its FRONT PANEL POWER CONTROL SWITCH EACH TIME before tring an other code.
OK.
Mar 12, 2011 | Orion Televison & Video
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Remote code for the tv
Hello
One amoung this will be your TVs' code.
Three digit remote codes for Philips Magnavox are:-
002/ 009/ 109/ 118/ 209/ 309/ 402/ 408/ 502/ 508/ 510/ 807/ 914/ 917/ 020/ 422/ 919/ 922/ 183/ 184/ 208/ 213
Four digit remote code for Philips Magnavox are:-
0062 0204 0207 0183 0226 0288 0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
NB: Switch OFF and then switch ON your tv with its front panel power switch [NOT BY THE REMOTE CONTROL HANSET]; each time before trying an other code.
Proceedings:-
Direct Code Entry
OK.
Dec 25, 2010 | Philips Magnavox 27MS343S 27" TV
Need Code for LC200EM8
Hello
Three digit remote codes for Emerson TV are:-
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit remote codes for emerson TV are:-
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Switch ON- and OFF the TV by its front panel power switch [not by the remote handset] each time before trying an other code.
Direct Code Entry
OK.
Dec 19, 2010 | Emerson EWF2703 27" TV
Tv does not stay on red light blinks 9 times
Power supply board it dead,replaced this board will get ur power back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 09, 2010 | Sony QUALIA 005 46 in. LCD Television
How do i set the date and time on my canon p23 dh v calculator
If you want to set the time, the button that has a picture of the calendar and clock (just to the right of the arrow key) until it shows the time. Then press and hold the date/time set button (just tor the right of the red minus button) for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits and the am/pm button for am or pm. If you need to set the date, press the calendar/clock button again until it shows either the date or the time, and then hold the date/time set button down for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits.
Mar 17, 2010 | Canon P23-DH Calculator
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
