Question about Philips HTS-6500/37 System
Green line on TV with DVD playing
Every time I play a DVD on the HTS 6500, I get a thin green line on the right side of the TV. It runs vertically from top to bottom. I am using a Philips Plasma TV (1080i). My old dvd player did not do this. How can I get rid of it?
Thanks!
  • Anonymous Apr 09, 2008
    I have the SAME problem with any HD HDMI source but not with the component or analogs!
  • Anonymous Jul 30, 2008
    vertical Green line on right side of screen 50'' from top to bottom when using HDMI cable on DVD player and just hooked it up to a PSP player and same issue. Taped it with black tape "LOL" to get rid of it but its still there driving me crazy how can I get rid of it other than covering it up.
The aspect ratio is fine, I just fixed mine you have to use the TV remote, and press the left or right directional button depending on where the green line. Philips TV offsets the picture when using HDMI, but its easily fixable using this remedy. Time to take the tape off haha!
Posted on Nov 26, 2008
Using your TV remote, press the right and left arrows to move the screen.
Posted on Mar 31, 2009
Using the left and right direction buttons fixed my problem. I am now enjoying 1080i and the picture quality from my DVR is exceptional. Thanks for these postings...
Posted on May 18, 2010
  • 26 Answers
I corrected the issue by simply going to the Setup Menu and setting ever thing back to the factory defaults. Moving the screen over will not solve the problem.
Posted on Apr 19, 2010
I had the same problem. Your aspect ratio is off. Just go into settings and make sure the dvd is set to the same size as the TV.
Posted on Jul 23, 2008
Green lines from cable not DVD
The fault will be with its feeder cable. Check for any break or loose connection to its fittings to TV. Check this link too. It will provide you some details about these type of faults. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 02, 2013 | Televison & Video
Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Oct 14, 2009 | Televison & Video
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
Thin green line
Most likely your tv has a defective LCD panel. If it's in warranty, drop it to the warranty depot shop to repair.
Jan 18, 2008 | Televison & Video
Philips hts 6510 no disk prompt does not play dvd
Ok looks llike a lens problem..Try this
Get a lens cleaner CD with liquid..Put two drops of liquid on the brush of the lens cleaner..insert the CD in your drive and play it..If it plays fine otherwise you will need to replace the lens..Get it replaced rather..should run you about 25-50$.If you want to get it repaired give it for repair only in a Philips showroom..
Oct 15, 2007 | Philips HTS-6500/37 System
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Philips HTS-6500/37 System Logo
1,839 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
