SOURCE: Hello, I had an issue with the door opening on my Comb O Matic 6200
no most washers you can open the door by 1st unplugging it take the lid off now place your hand flat move it down on the inside of the washer the side that your door catch is situated now when you feel the interlock if you fiddle around with your fingers you will be able to open it some have a cable going to the inside of your interlock pull on this and that will open the door just got it have patience while you fiddle with it you will get it may take a few minutes but it will happen
SOURCE: WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
SOURCE: cannot open door as handle broken for indesitw103
hiya easiest way to open is = first unplug power! then turn off water hoses to machine then draw machine out to gain access to pipe connections on rear and disconnect them ? now remove rear panel top screws as these also secure the top panel at rear then lift rear of top panel and pull to rear the panel now can be removed ? you now have access to the latch on front panel inside? if you reach down you can flick latch /hook clear to open door ? at this point after removing washing? you can observe the door inner remove inner panel that surrounds/secures glass? then you can observe how the door handle/lock assy is secured ? easy diy you can browse yellow pages for the replacement handle assy? machine repairs/spares reassembly is reverse to above wish you well this is a common occurance and should not have prob obtaining parts for the MAKE/MODEL NUMBER ? when enquiring for parts best wishes
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
