No sound I just purchased a VSX-1017TXV-K receiver and sound only comes from the right front speaker
  • 807 Answers
I assume you have the user manual for it.
If not it's here in Adobe Acrobat format .pdf file:
http://www.4electronicwarehouse.com/content/pioneer/vsx-101txv-k-manual.pdf
Just a thought but are you sure the speaker connecters on the back or the reciever are gripping the inner wire and not the plastic covering on the leads. Sounds daft I know but I have seen it before.
Posted on Mar 07, 2008
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
Aug 22, 2016 | Pioneer VSX-D307 Receiver
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Speaker sound will only come out of center speakers. The rear and front speakers do not have any sound
first is of course make sure hookup is still ok and then I would have the speakers checked (not likely) and last means a failure in the receiver itself--most shops for a fee will inspect it and give you an estimate.
Nov 06, 2012 | Pioneer VSX-405 Receiver
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Jun 17, 2010 | Pioneer VSX-1017TXV-K - iPod Ready, XM...
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Pioneer VSX-1017TXV-K.......it keeps shutting off at high volume..can't figure out why and have tried everything in the manual to stop it but it keeps doing it
Hello, your speakers are the problem or if your unit has a fan it is not working. Turn on the stereo at low volume. Take off the speaker grill (if you can) and put your ear up to each speaker in each cabinet. You will most likely find that a mid-range or tweeter speaker is not putting out sound. That's what I have seen the most in the 20 years or so of doing this. Good Luck
barneyluc
Oct 08, 2008 | Pioneer Audio Players & Recorders
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
94 people viewed this question
 Grubhead
Grubhead
