Question about Memorex MVDR2102
Memorex DVD Player
My sister just bought a dvd recorder and when I plug it in it says hello, then pls wait, then initial and thats where it stays.
  • 1 more comment
  • camanotim Apr 21, 2008
    MVDR2102 - stuck on hello. Connected and set-up unit correctly. Tested record function successfully by recording 2 hrs at SP with OTR. Finalized disc successfully. Tested timer recording per user manual - prepared blank disc for recording, set timer to record two programs of 1 hour each at SP. After timer set-up indicated "valid" I turned the unit off instead of pressing timer. Pressed the standby/on button on remote and panel displays "hello" but does not turn on. Pressed the Timer button - no change. Buttons on panel and remote are locked out. Reset unit per user manual - "Press Standby/Off button, then unplug unit for one minute" - no change. Unplugged unit for 5 minutes - no change. Sent email to "online" customer support [ www.memorexelectronics.com ] describing problem, so far no reply.
  • Anonymous May 12, 2008
  • edelight Oct 21, 2008
    I have the same problem. My MVDR2102 worked fine for recording quite a few DVD's from my VHS tapes. A couple of days ago, it froze, and all I get is "hello". It will not turn off unless I unplug it. I've tried everything. Very frustrating as I am trying to put old family home movies on DVD.
    Thanks for any help.
    Problem Solver:
  • 6 Answers
Peoblem is related to the IC incharge of the DVD rotation, it seems problem is related to a weak solder process, IC gets hot enough and IC pins get unsoldered not all but with one pin or more desolderd pins you have the problem.(Reballing) Solution resolder all pins on this IC Ic goes in the lower side of the MPEG Board and goes close to the side pointing to the DVD.
I fixed this way..EGYR
Posted on Sep 03, 2011
  • 46 Answers
Hello...please contact her dealer and try to replace the recorder if ther's a warranty...if not refere to the user manual.,and carefully read it regarding first useage...please tell me how it went...good luck...Ron
Posted on Mar 07, 2008
I have a GE universal remote that I am trying to program the code for the Memorex CD/DVD player model # MVD2040-FLR. The 4 digit codes given to me within the directions are not working. Any help for...
These are all of the codes available for the Memorex DVD Player:
DVD
MEMOREX ...........................0394 0446 1050 1118 1123
DVD Recorder
MEMOREX ........................... 1050 1118
VCR/Other
MEMOREX ..................0287 0245 0268 0304 0310 0329 0354 0226 0227 0337 0248 0251 0292
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 27, 2011 | Memorex MVD2040 DVD Player
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
Mar 14, 2011 | Memorex Televison & Video
Trouble with DVD+RW Disks being compatiable or staying formatted
cos they are cheap - get some decent branded discs such as TDK or tayo yuden and it should be fine
Also check the manual and or requirements on there website and it should show which are the best discs to use for that player but TDK or tayo yuden should be fine.
www.svp.co.uk or any where you can buy discs from should be fine
Apr 15, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Zenith XBR413 dvd/vcr recorder. Just bought some Memorex DVD+RW blank discs to do some recording. When I put the disc in the recorder it says "Unknown disc - check disc again" and pops the disc...
You may need dvd- disks instead! ( it usually one or the other!) and if your player does take a DVD+ you might have to change brands of disks ( I know this sounds stupid but all disks are not created equal! and do not work in all players!
Please rate this response and help keep this site free!
THANK YOU!
Jan 17, 2009 | Zenith XBR413 DVD Recorder
Dvd recordings will not play on any other dvd player
Initially, pls verify that all the recorded DVDs have been finalized, no further recording to be done on the disc. If this finalization is not performed, the recorded discs will only play on the unit it was recorded/created on and no other standalone player.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | GoVideo Televison & Video
RCA DRC8312 DVD/VCR player is stuck on Hello
The "H E L L O" message is part of the booting/initialization process of the built-in micro processor of the RCA DVD Recorder. Just like in a PC, it can also suffer from crashes/hangs.
Initially, pls try a reset. "disconnect it from all power and cable sources, leave off for 1/2 hour, then plug back in and hold the stand by buttons for the remote and on the machine at the same time"
If the above is not corrective, then you may have to consider a repair, probable areas to start checking would be:
  • firmware, might need a re-flash or update;
  • hard drive, might have bad sectors or require replacement.
Alternately, if you are not considering a DIY (do-it-yourself), you may have to re-evaluate the options since in some instances, cost and time of repair may no longer justify having the unit serviced.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Oct 11, 2008 | RCA DRC8312N DVD Recorder/VCR
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Initalizing DVD-Rs
are you using a quality brand of dvd-r like memorex.
Also after making a recording you must finalize the disc you recorded so it will play on other players.
Jan 08, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
My Memorex DVD Recorder (MVDR 2102) won't open
Most likely one or more capacitors on the main board went bad. I just fixed one last night with the exact symptom.
Dec 15, 2007 | Memorex MVD2042 DVD Player
Memorex MVDR2102 Logo
392 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
