Question about Apex Digital AT2708S 27" TV
Can't see the scroll at the bottom of the screen
This Apex AT2708S was given to me after my son could no longer play video games on it due to the fact that the bottom "scroll" area is "below" the plastic frame of the TV. I do not know if a component in the TV has changed so that the picture has become "taller" from top to bottom or if some technical setting has been inadvertently changed. I understand there is a "technicians service menu" that can be accessed if I know the right codes to get into it. I would like to try adjusting the "vertical hold" on the set to see if I can bring the scroll area within the viewable area of the screen.
  • 1 more comment
  • dfair2 Aug 30, 2008
    Can't see the scroll at the top, bottom or the sides of the screen problem, need the access procedure to get to internal adjustment on Apex AT2708S 27" TV... thanks dfair2
  • mgore25 Sep 03, 2008
    can't see the scroll on the bottom of my APEX AT2708S. I got to the service menu but don't know which item to adjust. I used the instructions below:
    __________
    if you turn the vol. down to 00 then press mute on the remote then hold mute on the remote and menu on the tv for 3 seconds you will get the service menu and you can adjust the screen.
  • Davids_39 Feb 02, 2009
    I have a similar problem. We inherited this TV from a family member. It appears that the 'resolution' is incorrect. By this I mean that the edges (top, bottom, and sides) run off the side of the TV while watching TV and playing the WII. When we have our digital satellite menu up, the edges appear to be squished. I'm able to get into the service menu, but I have no idea what any of the menu options are for and what I might need to change. Any help would be much appreciated!
I was having the same problem. if you turn the vol. down to 00 then press mute on the remote then hold mute on the remote and menu on the tv for 3 seconds you will get the service menu and you can adjust the screen.
hope this helps.
Posted on May 15, 2008
How do I unlock an apex at2708s
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Aug 12, 2014 | Apex Digital AT2708 27" TV
How to unlock at2708 apex tv
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Apex Digital AT2708S 27" TV
On my Apex TV screen, some of the picture is cut out. How can i adjust the TV resolution?
You cannot adjust the resolution in CRT TVs. Its not like a monitor that is compatible with a number of resolutions from a computer for example. CRT TVs resolution's dont work like that.They take an input usually from a composite, Svideo or coaxial source and display it on the screen.
When you say the picture is cut out is there a black bar on top/bottom/middle of the screen? In older CRT TVs that usually means a problem with the TV itself and would need to be taken in for repairs or replaced.
Mar 05, 2011 | Apex Digital AT2708S 27" TV
I have an APEX, model no AT2708S, s/n DF282374776, MFG no D128C3SV2A237477 that i purchased new several years ago. Will I need a converter to access over the air channels now?
Yes,this tv is an analog tv,free air tv channels are all digital now.Tries walmart,Target stores,might still sell these digital converter boxes.Not,tries websites like Amazon.com,Ebay.com they still sell these converter boxes.
Nov 25, 2010 | Apex Digital AT2708S 27" TV
My apex tv model AT2708S is locked and i can't find manual
CHILD LOCK The Child Lock feature prevents unauthorized viewing of the TV. To activate, press and hold the F key, and then press MUTE. You should see a key symbol appear on the screen. This will lock out all remote functions (except for Standby). To unlock the TV, press and hold the F key and press MUTE. This will unlock the TV. Please note that the only way to activate or deactivate the Child Lock feature is via remote control - please insure that it is stored securely.
Aug 20, 2010 | Apex Digital AT2708S 27" TV
Where is the 3-4 selector switch located on my 27'APEX TV, so that I can play a DVD using a DVD player
Should be a video button on the tv and also on the remote,Or use the channel button and change channel to 0
Apr 05, 2009 | Apex Digital AT2708S 27" TV
No sound and picture does not fit tv screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ...
Jul 25, 2017 | Apex Digital AT2708S 27" TV
The bottom screen of the nintendo ds is broken and the colors are "runny" looking...so I can't use the pen or play the game. how to fix, or where can I take it to have it fixed? thanks
Hi.
You can buy new touch screens on Ebay and other web sites (tend to be cheaper on Ebay). You can also download instructions for installing the new screen. I have done it for my son's DS and it is surprisingly easy. You will need a special screwdriver to open up the Ds, but you can buy these - in fact often they come with the screen.
Dec 09, 2008 | Nintendo DS Console
Apex tv want turn over
a small red key is at the bottom please help
May 31, 2008 | Apex Digital AT2708S 27" TV
The play game icon not showing on his PSP
Is there a disc in the drive? If so, it sounds like your UMD drive (or disc) is damaged. Does it only happen with one game or with all your son's games?
Dec 19, 2007 | Sony PlayStation Portable (PSP) Console
Apex Digital AT2708S 27" TV Logo
416 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
