Question about Acer NSK8458AN Keyboard
The keyboard only types in upper case
The caps lock light is not illuminated - I have tried to clean the keyboard but it still types in upper case only....... I don't want to remove the keys as I may have problems getting them back on. My external keyboard works just fine so I'm guessing it's 'dirt' under they keys? Do you have any other ideas?
Ann
  • jimmyQ3 Mar 14, 2008
    My very new, very clean, Logitech wireless Qwerty keyboard will only type in uppercase. How do I fix it? Pressing Caps Lock key does not fix the problem. Help
2 Suggested Answers
Destinova
  • 46 Answers
SOURCE: types in upper case only (without caps lock/shift key locked)
in most cases yes, BUT since the light for caps lock is not comming on you might have a bad P.O.T. on the keyboard layer.. Since im assuming we are talking about a laptop..
Posted on Mar 07, 2008
How to identify whether the keyboard is in upper or lower case - eg when typing in a password as there is no light or any indication at all (MK250)
On most any keyboard there are 3 lights indicating whether or not your caps lock, num lock, or scroll lock are on. Also my programs have a default notification that lets you know when your typing a password, if the caps lock is on or not!
Aug 10, 2011 | Logitech Wireless Access Duo Optical...
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Cannot find the upper case indicator (light) on the keyboard
More than likely you have purchased a keyboard without the lights. There is such a thing. I would try pressing the Num Lock, Caps Lock, and Scroll lock keys. If the keyboard has lights, you should easily be able to see three lights lit up. If not it is pretty safe to assume that the keyboard has no lights. Next time if you were to list the name and model of keyboard it would be easier to diagnose problems. More info is almost always more helpful. Hope this helps.
Mar 23, 2009 | Computers & Internet
How do I know if I am in lower or upper case as there are no lights indicator on my logitech new keyboard.
Well I guess you will know when you try typing, if there is no light indicator on the keyboard ( well there just dumb ) and you can't do anything about it.
Jan 05, 2009 | Logitech Cordless Desktop MX 5000 Laser
Status light on upper right illuminated - how to turn it off?
Initially, have you checked/pressed on the "Scroll Lock" key (between Print Screen & Pause). To my knowledge, on most keyboards, the three common indicator lights are: Num Lock, Caps Lock and Scroll Lock.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Ingram BTC-5199 Keyboard
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Types in upper case only (without caps lock/shift key locked)
Mar 07, 2008 | Acer NSK8458AN Keyboard
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Acer NSK8458AN Keyboard Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
