Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
No lights on the control panel
Ive checked the wall switch and the circuit breaker and still none of the lights on the control panel come on the dishwasher doesnt work
  • 1 more comment
  • Jeannine Smith Mar 28, 2008
    My GE Profile 9800 series was just installed today. The installer had it running when he left. This evening I went to set the controls for the hardness of the water and noticed that none of the electronic panel would light up, nor could I get the the dishwasher to run. Any ideas?
  • mtiidus Nov 06, 2008
    contrl panel is electronic, touch contrl interface. Machine was running on normal cycle, opened door to put in more dishes, closed door and machine did not start and control panel contols not reponding, normal light remains illuninated. Nothing else lit up.
  • malhsk May 26, 2009
    Three digit display is on but none of the lights are on. Diswasher won't start.
  • 131 Answers
Check the thermal fuse at the control panel, the door switch, or the electronic control.
Posted on Mar 10, 2008
I havea 30'50 citation trVel trailer and none off the wall sockets work e cept by telivision
depending on the voltage for the sockets , check for a circuit breaker tripped and get in an accredited electrician
Feb 09, 2016 | Office Equipment & Supplies
This is the fuse panel cover for a 1999 1500 Chevy Silverado which fuse controls the driver side window switch
The picture is too dark. Usually the power windows, all of them, are protected by a 25 or 30 amp circuit breaker. It is usually found in the instrument panel fuse block, under the dash on the driver's side. The circuit breaker is a matchbook size "fuse", usually silver colored. A circuit breaker automatically resets if it gets tripped by like a short.
If you pull off the master switch, the driver's side switch, you should have one hot wire with key on. The power wire and the ground for the windows are both in the driver's master switch. This is where you begin testing the power windows if none are working. Check for a hot wire, and check the ground wire- use a multi-meter.
Jul 19, 2015 | Cars & Trucks
No power in back bedroom
Locate your circuit panel, and check your fuses/circuit breakers.
Maybe breaker tripped?
To reset, remember: All the way to OFF position first, then flip towards ON.
Jun 09, 2015 | Televison & Video
Control panel lights not working and none of the buttons resond
Power? Has circuit breaker popped? Possible you have ground fault protected outlets and one of them popped like a circuit breaker. It usually causes all outlets on that circuit to also disconnect. They have a reset button similar to other circuit breaker devices, so double check. If it pops again, you may have a serious electrical problem or appliance problem. Unplug all appliances plugin one at a time to discover bad appliance. If none are bad and you still have frig problem. Time to call an electrician. You may be able to verify frig via extension cord from an outlet outside the kitchen. That if lights and buttons work, then you know it's the kitchen circuit problem. If not you may have a major problem with the control panel itself. Time for an appliance technician.
Feb 27, 2015 | Hotpoint Refrigerators
How and where do I check the fuses?
if i rememember right is this the one that door handle needs to be locked for front panel to light up ? if so you have a broken door switch , Happens!!!! ive replaced a few of these
Feb 20, 2015 | Maytag Stainless Steel Jetclean Plus...
No power lights
Check circuit breaker to see if it is on, Then check the wall outlet to see if you have power to the machine. Turn off the breaker and open the control panel. See if there is a blown fuse. If the fuse is either not there or is not blown, turn the breaker back on and CAREFULLY measure the input voltage to the control panel main switch. If it is not there, check the door safety switch to see if power is there...Lots of troubleshooting...Have fun!
Dec 27, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
What do I do now
If the dishwasher is not available, you can carry out the following checks:
Step 1: Check to make sure the power supply. If it has a plug in the wall outlet, then check the wires, plugs and sockets, to ensure that they work properly. Also check the control socket of the switch, make sure it is closed. The vast majority of embedded dishwasher are directly connected with the line. Check the main control panel on the fuse is blown, the circuit breaker is disconnected, then recovery circuit. If your home is old-fashioned dishwasher, it may be associated with the sub-control panel is connected. Check the fuse or breaker panel, and then restore the circuit.
Step 2: If the line has been energized and the wall outlet is controlled by a switch, the switch is likely bad. Use a voltage tester switch. Remove the switch cover, a probe is placed at one end of the tester, another probe placed in the other end. If the detected light switch is good; If you do not, it is bad, you need to replace a switch of the same model new.
Step 3: Make sure that the the Xian bowl machine's door shut furrowed good. Only when the latch snap, the dishwasher before running. Check latch should shut door and lock, firmly hold down the latch, then the control knob to the "start". If the dishwasher can work, said latch is broken and needs to be cleaned, reinforcement or replacement.
Step 4: Make sure that the water supply, and the water temperature is high enough. The failure of the water heater will prevent the dishwasher water. Check the kitchen sink with hot water or bathroom. If we can release hot water, the water heater should be no problem.
Step 5: Make sure that the control panel controls are set correctly. Button controls the more new more sensitive. Make sure that these keys are firmly safety in the corresponding position.
Dec 17, 2012 | Dishwashers
Both the fan and the light stop working. What are the first things to try?
Good way of asking for help!-- Thank you!
First make sure the circuit is not tripped at the Circuit Breaker--
(Are other lights on the same circuit still working OK?)
You will need to verify which breaker controls the voltage to this fan--
and you will need to turn the breaker OFF, while dismantling the fixtures.
Can you communicate with someone at the Breaker Box, while you work safely?
Have them turn the circuit on when you are safe and ready -- and reading voltage, etc.
Next-- Do you have a dimmer switch, (or just a wall switch) on the wall?
Do you know if the power is supplied to the ceiling, thru that wall switch?
If so, check to see if the dimmer or the switch has power coming in and out at the wall, and heading up the ceiling supply wire.
If the power is supplied at the ceiling, then you are going to have to get a safe ladder, and remember Ladder safety rules!
The tough part, is getting the heavy fan and light assembly safely down, where you can make some voltage readings at the supply circuit wires at the ceiling--
Maybe you have found a loose wire nut by now?
Or maybe a defective dimmer or wall switch?
Or what are you observing at the junction box, and the fan motor now?
Tell us more-- and we'll see if we can help yo to the next step.
Mack B,
Jan 18, 2011 | Hunter Ceiling Fan Control Switch
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
The water doesn't stay at the bottom of Dishwasher & The detergent doesn'e get totaly emptied out from detergent Tray. It looks like the the residue remain in the Dishwasher & On Dishes too. Please, help...
hi there,
no indication that machine is not working,is there any power supply,check the power source,circuit breaker switch on.
Step 1: Check to make sure it's receiving power. If the unit plugs into a wall outlet, check the cord, the plug, and the outlet to make sure they're functioning properly. Also check the switch that controls the outlet to make sure it's turned on. Most built-in dishwashers are wired directly into a circuit. Check the main entrance panel for a blown fuse or tripped circuit breaker, and restore the circuit. If your home is an older one, the dishwasher may be wired to a separate entrance panel; look for a blown fuse or breaker at this panel, and restore the circuit.
Step 2: If the circuit is receiving power, and the wall outlet is controlled by a switch, the switch may be faulty. Test the switch with a voltage tester. Take off the switch cover plate and place one probe of the tester on one terminal and the other probe on the other terminal. If the tester bulb lights, the switch is functioning. If it doesn't light, the switch is faulty. Replace the switch with a new one of the same type.
this should be done by appliance technician,but if you have knowledge on this check it out.regads have a nice day,dont forget to rate me thank's
Apr 30, 2009 | GE 25 in. Profile PDW8200J Built-in...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
734 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
