Question about Dryers
I have a Whiilpool electric dryer that has an Accudry sensor. WHERE IS THE SENSOR LOCATED? It takes twice as long to dry as it did 6 months ago. Model of unit = GEQ8858KQ0
    President:
  • Dryers Master
  • 2,651 Answers
The "moisture sensors " are located just to the right side below the lint filter housing. pop your hea inside and youll see 2 metal strips. thats them. with a scotchbrite pad, you can clean them off, usualy become fouled by dryer sheet residue. twice as long to dry couldalso be an indicator of a vent thats not completly free, kinked or becoming clogged .
Posted on Mar 07, 2008
Front door willnot stay closed
Hello Shirelle,
The door lock mechanism is defective Or the door seal is seating properly.
Jul 04, 2015 | Whirlpool Cabrio WED5500X 27" Front-Load...
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
Kenmore dryer only heats on delicate
I am not familiar with this particular dryer but most of the Kenmore family use different thermostats for different temperature. They are usually located in the rear and are clustered on the blower housing. Take the two wires off one thermostat at a time and test. It should be closed when cold if not replace it (Usually around $15 each) You probably have a very dangerous clogged exhaust. This will cause thermostats to fail. and can cause a fire. CLEAN It out and dont use flexible plastic duct pipe. The other cause of thermostat failure is if the washer doesn't spin properly and the clothes are too wet when dried. A properly operating dryer will not take much longer than 45 minutes max to dry a load.
Jun 14, 2008 | Dryers
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
393 people viewed this question
Top Dryers Experts
