Question about Philips 60P8341 60" Rear Projection Television
60" philips projection tv
Hi i have a 60" philips projection tv model#60p8341. I was having problems with it just shuting off. I did some looking on the net and evryone was saying it was the SSB module so i bought one and changed it. It stopped shuting off but know it will be good for a couple of minutes and then the picture will get really broken up and the sound gets chopy. any sugestions.
thanks corey
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Posted on Apr 30, 2008
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
Oct 28, 2014 | Philips 60P8341 60" Rear Projection...
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Model Philips 60P8341 60 inch
Most common problem for this is the Flyback transformer/trippler. If you would like to try the repair yourself let me know and I will help you. If not a repairman should charge you around $400-$500 for the repair. Let me know what I can do to help!
Tim Nolan
Sep 11, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
PHILIPS 60P8341 PROJECTION TV NO PIC NO SOUND
Thats the DPTV 300 series phillips HDTV its definatly worth fixing. How are your troubleshooting skills. Sounds like either a problem in the LSB or SSB circuits boards. On our website we have replacment circuit boards for that model. Our prices are less than half what others are getting. Let me know if you would like me to post a link, we also have the service manual for your model.
Mar 08, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60P8342
Iam looking for this part 313501707611 it's that board brook
Dec 19, 2007 | Philips 60P8341 60" Rear Projection...
I have a philips 60p8341 tv
Hi, the fluid in the tube has to be replaced, big & dirty job, set has to go to the shop to do this, be advised that this happens to all Philips rear projection tv`s eventually, problem is (besides being expensive to do) if the green fluid is getting cloudy the blue tube is not far behind. This can be confirmed by removing back bottom cover and looking directly into the lenses, you`ll see they are cloudy compared to the red one that almost never becomes cloudy, sorry to be the bearer of bad news, if you have more questions ask away, BMW Rider
Dec 10, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
