PRINTER NOT WORKING PLEASE HELP!!!!!!
Head align head keeps blinking, i tried to auto line but only prints two box lines and two smaller box line. and i tried printing something and nothing copies. my printer is the pixma/mp780/canon. thanks
  • manyx69 Mar 07, 2008
    thanks, but didn't work .
  • 490 Answers
Uninstall and reinstall the printer driver
S. Mohan
Posted on Mar 07, 2008
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Office Equipment & Supplies
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Reinstalled MP610 but printing edges still not clear. It's almost as if there are tiny handles spaced around the edge of images (bracketing where the lines used to be before I changed ink.. What could be...
Try do a auto head alignment in case the printer is off center. Go to your main menu of your printer then setting - maintenance - auto align head. This should fix your problem if not try a manual head align this will print a piece of paper out and you can scan it through.
Nov 13, 2010 | Canon MP610 Photo All-In-One Printer
Faint & White Lines in Printer Head Alignment
This sounds like you are using either a refilled cartridge or an after market cartridge and the ink is clogging the print nozzle. To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity, alignment utility. This should clear up the problem with the spotty printout.
Let me know if this solves your problem otherwise we can explore other solutiions.
Please rate this solution. Thanks.
Oct 06, 2009 | Canon BJ I6500 InkJet Printer
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Jan 20, 2009 | Canon PIXMA MP970 InkJet Printer
Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Mar 07, 2008 | Epson Stylus Photo 1290 InkJet Printer
Computers & Internet Logo
Alun Cox
David Payne
David Payne
