Question about HP LaserJet 1320 Printer
Letteres printed on a Monochrome printer offset type onto themselves
Letters that are printed on good stationery, folded and mailed arrive with type offset onto the parts of the sheet they contact. I know that the rollers that sort the mail at the post office cause this but it only happens with my thicker better paper (24 lb.). It does not happen with thin white copy paper. I was told it could be the fuser roller. I replaced the printer with a new one. Same problem. Can a laser printer print type that will not transfer itself to another sheet when presure form postal sorting rollers are applied?
    Master:
  • 555 Answers
Which print finishing setting do you use: Draft, Normal or Best?
Posted on Mar 07, 2008
  • Matt Jurach
    Matt Jurach Mar 07, 2008
    I ask in order to determine if it is excess toner that is being transferred.
    Is there just a shadow of the text that is transferred onto other parts of the paper (excess toner)? In other words, the original text is still completely intact and legible, but maybe just a little lighter as some excess toner has been transferred away.
    Or is the toner moving totally away from the print area and onto other paper surfaces? In other words, whole pieces of toner are missing from the printed area and are instead found on other parts of the paper.
  • Matt Jurach
    If it is the first, then the answer is that you should use less toner. Try "Normal" instead of "Best," or "Draft" instead of "Normal."
    If it is the second, where whole toner chunks of letters are moving from the printed area to other parts, then I believe the issue is with the type of paper you are using.
    Get paper that is rated especially for laser printing. Since this is an HP, I recommend getting HP Laser Paper. It is specially designed to adhere with HP toner.
I cannot find a template using Microsoft Word - Envelopes & labels for Avery label #6873.
Try this:
  • On the tools menu, point to letters and mailings, and then click on mail merge
  • Under select document type, click envelopes the active document becomes the main document
  • Click Next: Starting document.
Aug 06, 2008 | Office Equipment & Supplies
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
THe datacard sp55 color card printer is printing monochrome(black and white). I have done lots of setting changes but still couldn't manage tro print the right color. And the duplex module is not on the...
The printer needs to be serviced, The Monochrome issue could be related to a problum with the RFID chip in the take up wheal of the ribbon, but the duplex offset can only be adjusted by an authorized service provider using a special password and diagnostic tool.
www.TulsaBiz.net offers a depot service.
Aug 26, 2010 | Datacard SP55 Plus Printer
I want to change my font in MS Outlook. Now is Calibri with letters in light blue color, tough to see. I want to default to Arial and black letters. I can change to that each time I respond to a...
Select "Tools | Options..." from the menu et081706_3.png Select "Tools | Options..." from the main Outlook window's menu
Heinz Tschabitscher
  • Select Tools | Options... from the menu.
Go to the "Mail Format" tab et_default_font_outlook_1.png Click "Fonts..."
Heinz Tschabitscher
  • Go to the Mail Format tab.
  • Click Fonts... under Stationery and Fonts.
Use the "Choose Font..." buttons to select the desired font et_default_font_outlook_2.png Use the "Choose Font..." buttons to select the desired font
Heinz Tschabitscher
  • Use the Choose Font... buttons for When composing a new message:, When replying and forwarding: and When composing and reading plain text: to select the desired fonts and font styles.
  • Click OK.
    • If stationery is defined to be used by default under Use this stationery by default:, the font specified in it may override the font you have just specified. You can either choose "<None>" as the default stationery, adapt the stationery to include your favorite font make outlook ignore font specified in stationary altogether.
Make Outlook Ignore the Font Specified in StationeryTo set Outlook to ignore fonts specified in stationery and use the default instead when composing a message:
  • Make sure either Always use my fonts or Use my font when replying to and forwarding messages is selected under Stationery fonts.
  • Click OK.
  • Click OK again.
Jul 29, 2010 | Computers & Internet
I have a HP 5610, print very small letters
Go in the printer preferences and change the options to "print as in document" and make sure that 'scaled to it is not checked'.
Maybe, you scaled it down by accident. Also, make sure that you didnt choose 8 points in the original document. Otherwise, it will print small
Aug 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Toner prints onto adjoining paper in the mail.
maybe it is excess toner, or the paper type my be the wrong type to use, try some other type
Nov 17, 2008 | Canon imageCLASS D880 All-In-One Laser...
Mail merge tri fold printing
Whats the weight of the paper? Try a lighter weight paper. Also, did it do it when you first got it? If No, it is called a limitation, it can't be done. If it did have your service tech come out and clean or replace the feed rollers or clutchs.
Feb 04, 2008 | Panasonic DP-C264 Copier
Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Oct 04, 2007 | HP LaserJet 1320n Printer
HP LaserJet 1320 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
