Question about SanDisk Sansa e200 MP3 Player
My sansa e200 wont come on
Tonight i tried to charge my sansa e200 and it would not come on at all...i tried putting it on hold and pressing mic and menu at the same time. it still wont work. PLEASE HELP ME!!!!!!!
  • Tuibe Mar 09, 2008
    I too have the same problem.
    It simply does not turn on at all.
    What is the solution, any case number?
Try geting a new charger that what i did and it work
Posted on Mar 09, 2008
The mp3 player is frozen once it turns on. Keeps on saying refreshing your media.
Press and hold the power button. Hold it long enough (10 to 15 seconds ) it will eventually turn the frozen player off. Press the power button again to turn it back on. You can try formatting the player again either through windows media player or (if a v2 model) through the player's own menu system. Failing that, put the player in MSC mode and format it from Windows Explorer. I would also update the firmware. I have attached the link to the Sansa site to find the firmware and further instructions.
Thanks for using FixYa.
http://forums.sandisk.com/t5/Sansa-e200-series/bd-p/e200
May 29, 2011 | SanDisk Sansa e250 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
  1. Turn on the e200 v2
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for the e200 drive(s) to show up
  6. Follow instructions below and drag files to the e200 drive
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
Sep 06, 2008 | SanDisk Sansa e260 MP3 Player
Uploading songs on it
you could try putting it into recovery mode if it's like the sansa e200 series. to do this plug it into your computer and click the hold button so the orange is showing. next, hold down the record button while pushing and holding the power button at the same time. after a few seconds it should go into recovery mode and factory settings will restore. this works for sansa e200's and i hope yours is almost the same as them. try the sansa forums though they could help alot.
best of luck
Feb 14, 2008 | SanDisk Sansa Clip MP3 Player
Charging sansa mp3
try putting it into recovery mode. you can do this by putting the hold sign to where it shows orange, then holding the record button down while holding the power button down and continue to hold them at the same time. make sure your sansa is plugged into the computer while you put it into recovery mode. for more information here is a link to the forums where they tell you how to put it in recovery mode http://forums.sandisk.com/sansa/board?board.id=e200
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e260 wont turn on or charge
I had the same problem. Place the device into hold and press the menu and mic buttons at the same time. The first time I tried it, I had no response and then I pressed the same buttons again and my e260 came back to life.
After getting my e260 to come on, I updated the firmware and everything has been working.
Jan 27, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 froze
hold the menu button for about 15 sec. and it'll turn off
Dec 28, 2007 | SanDisk Sansa e200 MP3 Player
HELP WITH SANSA E260
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
Rebooting sansa e200
press the hold button the press the record button for like 5-8 sec.
May 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
