Question about Roper FGP325K Gas Kitchen Range
Burner goes out on simmer
Kenmore gas stove model 911 36659590 Evidently built by roper. All the burners work properly, but when on simmer burn very low and tend to go out, allowing gas to escape into the room.
  • ozzue Mar 07, 2008
    Thanks for the advice, you made me give a second look at the valves. The shaft was solid, but there was an adjustment screw offset and behind the shaft on the valve that that was just reachable with a thin flat head driver. It was not visible without a flashlight as it was set well into the body of the valve. The stove now works great on simmer! This stove had been converted to LP by the original owner, so I had to adjust all 4 burners, after replacing the jets.
    Thanks Ozzue
    Top Expert:
  • 2,907 Answers
Sometimes the burner holes get clogged. I use a toothpick to clean out the holes.
Hope this helps.
Posted on Mar 21, 2015
    President:
  • Roper Master
  • 2,651 Answers
Look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Posted on Mar 07, 2008
WHEN LEFT FRONT BURNER IS ON SIMMER ITS FINE..WHEN PUT TO HIGH IT GOES FOR A FEW MINUTES THEN THERE IS A PUFF OF FLAME AND A BANG..WHAT COULD THAT MEAN ALL OTHER BURNERS WORK FINE
Hello, Bob -
I hope I am correct in understanding your question is in reference to a gas stove. If so . . .
The following information is from:
http://www.home-repair-central.com/gas-stove-troubleshooting-guide.html
Personal opinion: You need to have a gas stove repair person who is authorized to work on your make of gas stove inspect it and determine what repair is needed.
Jan 12, 2018 | Kitchen Ranges
Carbon residue on pots
There is an adjustment for correcting the air mixture on the gas line going from the knob to the burner. It usually is located at the point where the adapter nozzle enters the gas line going to the burner.
Aug 13, 2017 | Kitchen Ranges
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Kenmore oven doesnt bake
Can I assume that you determined that the bottom burner flame is burning properly? To do this, remove the oven bottom insert. The flames should have approximately 1" of blue cone and should burn with no yellowing tip, if on natural gas. (A small yellow tip on the end of the outer cone is normal with most LP gas.) The flmaes should not lift off the burner ports. If the flame is lifting, gradually reduce the air shutter until the flame stabilizes.
Go to the following website for your particular manual.
http://www.hammerwall.com/Manuals/Kenmore/Description/362.75585890/Kenmore%20Free%20Standing%20Gas%20Range%20Owners%20Manual/L0522834/
Feb 16, 2010 | Kenmore Ovens
My four burner electric stove top is not heating properly. When I put it on simmer it goes way too hot on all the burners? The switch? The thermastat?
need model # not a common problem when all will do that, if only one bad burner switch but when all do that could be shorted wiring
Oct 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Thermador model RDF30RS burners won't light
Hi, there are two small circuit boards on those burner controls. They are called potentiometers. There was probably a boil over or spill at some point. They are notorious for failing. Hope that helps.
May 04, 2017 | Kitchen Ranges
Roper FGP325K Gas Kitchen Range Logo
483 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Craig Butler
Craig Butler
Jim Thurston
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
