Question about Car Audio & Video
Venturer cd/dvdcar head unit
I have a venturer dual cd/dvd player that i hooked up but when i put a movie in it comes up on the screen that"its unlawful to drive and watch a movie please engage the emergency brake " ... while thats on the screen i have sound to the movie but it wont let me watch it ... wat else can i hook the yellow wire on the back to so it will let me watch it without actually hookin it up to the e- brake ?????
Is what you do its take that yellow wire and hook it to a toggel switch and then ground it out then when you want to play a movie you just got to flip the switch a few time till the dvd starts to play
Posted on Sep 29, 2008
    Champion:
  • 227 Answers
Ground the brake wire(light green) to the frame. Goodluck.
Posted on Mar 07, 2008
One screen is blue but the DVD will play you can hear the movie but no picture on the screen
open the cover the dvd player,try to check connector from mother board thru lcd,if loosed connctor.
Mar 11, 2010 | Power Voice System Venturer 7" Portable...
Xdvd710
No - there aren't any codes to unlock the playback without the e-brake.
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 15, 2008 | Dual XDVD8181 Car Video Player
Dual dvd stereo bypass
Aug 11, 2008 | Kenwood KVT-617DVD Car DVD Player
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 31, 2008 | Dual XDVD8181 Car Video Player
PYLE PLTSD7BT
Jun 28, 2008 | Pyle PLBINDV7 Car DVD Player
No picture
Jun 27, 2008 | Dual XDVD8181 Car Video Player
Car stereo/cd/dvd player
Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done. If you can't get it to work with this process (or whichever process the manufacturer describes in the manual), then that wire may not have been hooked up, or could have been hooked up incorrectly. You'll probably have to remove the head unit to investigate this.
Jun 16, 2008 | JVC KD-DV5100 CD Player
Jensen model#vm9411
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the blue one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Feb 25, 2008 | Jensen VM9411 Car Video Player
Dual Screen not working
I`M TRYING TO HOOK UP THE OTHER SCREEN THE DVD PLAYER PLAYS FINE BUT I CANT HOOK UP THE OTHER SCREEN TO IT HOW DO I HOOK IT UP
Aug 13, 2007 | Power Voice System Venturer PVS1988...
Car Audio & Video Logo
167 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
