Back to:
Tags:
Haier XQG50-11 Front Load All-in-One Washer / Dryer
Haier Washer M # XQG50-11
posted by Kooler22 on Mar 07, 2008
Sounds like main drum bearing is gone. What's involved to replace it? Is it an outer tub replacement?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 08, 2008
Helpful (85)
EmgSupport
Rank:Master Master
Rating: 88%, 10 votes
Once you remove the rear access panel, you would see the main pulley on the rear of the outer tub. You need to remove that nut with a metric allen wrench. once the pulley is off, you can then remove the bolts holding the yoke in place. The Yoke and the bearings are available as a part assembly from haier. It is highly unlikely that you would need to replace the outer tub.
Rating Locked! (?) Kooler22 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Haier Washer M # XQG50-11:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Haier XQG50-11 Front Load All-in-One Washer...
I have a Haier XQG50-11 front load washer/dryer combo that...
2 problems.  First, the water baffle - a rubber piece...
My Haier washing machine keep on giving eoor E2 everytime...
Err7 flashes up when i put spin cycle on
The slow spin part of the cycle works fine but the high...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
