Question about Epson Stylus RX650 All-In-One Printer
Installation problems When I install (or try to install) the RX650 via USB my computer does not seem to recognize the printer as a printer--the message indicates that the item connected is unknown. The computer is an older model PC running Windows XP. I have been able, at times, to get both the printer & scanner operating in unison with the computer, but if I shut the system down for the night, the same problem is probably going to return the next time I turn the computer on. Since I bought this particular unit because of its ability to scan slides, at this point I feel like scanning the slides that I have and then selling (or discarding!) this all-in-one printer. Any advice you might offer will be much appreciated. Harold Albert Thailand
    Genius:
  • 1,027 Answers
Unplug the printer's USB cord, and from the control panel, uninstall the printer drivers. Re-install the printer drivers, THEN plug in the printer.
Posted on Sep 02, 2008
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
IBM Thinkpad G40 not recognizing replacement hard drive
my recommendation is to format the drive and see if that helps. do it via usb.
May 05, 2012 | IBM ThinkPad G40 2389 (2389HEU) PC...
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
My computer does not recognize my printer
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
Jun 10, 2011 | Dell 946 All-In-One InkJet Printer
My hp psc 1315 all-in-one printer will not download to my hp pavilion .
so its usb? The HP installation media will walk you thru installing it, at a certain point it will tell you when to attach the device.try that.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 26, 2009 | HP PSC 1315 All-In-One InkJet Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled...
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
Windows XP SP3 doesn't recognize HP 1020
Check in control panel/device manager and see if there are any red or yellow exclamation marks and while there see if your USB is installed
and if find problem contact us at our tollfree no 18884276640
Jun 23, 2009 | HP LaserJet 1020 Printer
Having trouble installing HP Photosmart All in One Printer. Model C5280. Near the end of installation it ask's for printer to be connected via USB cable. Msg comes up on screen 'USB Device not recognized'...
Dear Sir:
It seems that the printer has gone bad because when you get this message 'USB Device not recognized' it means that the usb device connected to the computer is defective however I would suggest you to connect this device to another computer and if you are getting the same error with the other computer.
Please contact hp support they should be able to help you with this.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Jul 19, 2008 | HP Computers & Internet
Epson Stylus RX650 All-In-One Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
