Question about Zebra Z4M Printer
Labels sticking to ribbon
When printing most of the labels stick to the ribbon. Is there any way of fixing this
If I had a guess...this label material sounds old or stored improperly...possibly to much head pressure....I would suggest some known good material and retry.
Posted on Apr 16, 2008
Tip
Determining whether your ribbon is CSO or CSI
A ribbon used in thermal printing will be either:
  • CSO - Coated side out
  • CSI - Coated side in
The ink is on one side or the other of the roll of ribbon. To determine which side the ink is on, take a label and stick it to the ribbon and peel it back off. Ink will stick on the adhesive, turning it black on the side that has ink on it.
on Aug 20, 2010 | Office Equipment & Supplies
The Ribbon is sticking to the paper, as the paper is fed. The rewind motor shaft is turning also.
check that you are in thermal transfer mode in the driver.
- Check in the diagnostics mode that the ribn Adj Fwd is not -15
Normally should be zero
Sep 26, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
The letters are not all printing on my label. It prints only parts of letter(s) and number(s) sometimes not at all . we just moved offices and I can't find the manual. I thought maybe it was the imprssion...
Some labels are very glossy and correctable ribbons don't stick well,
Try moving the impression to the hardest setting and setting it to bold print or get a lable with a matt finish.
DickyO
Jun 24, 2010 | Swintec 7040 Typewriter
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
Ribbon and media sticking together bypassing cutter
Make sure that the ribbon options are turned on the printer. If you recently switch from using thermal stock which doesn't require a ribbon, then it needs to be turned on in the control panel of the printer.
If it is on, remove the ribbon cartridge from the unit and manually turn the wheels to make sure it is moving freely.
Nov 20, 2008 | Zebra 105SL Thermal Label Printer
Troubleshooting Argox OS-214 Label Printer, Support
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Jun 06, 2008 | Argox OS-214 Label Printer
Zebra Z4M Printer Logo
194 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
