Antenna conector problems signals a re interminent when wiggleing the ant. conn.
Your problem is more than likely due to a bad/broken connection on the inside of the antenna connector. If you're brave, and handy with a soldering iron, you can open the case and check/resolder the two joints at the connector. Otherwise, take it to a local electronics shop. It's a simple repair, but only for those who know their way around inside a scanner.
Bill B
