Question about Panasonic Audio Players & Recorders
SA-AK87 F61 error
The minute i turn on this mini compo, it flashes F61 and then just turns-off automatically, please help, thanks so much
  • melneey Oct 10, 2008
    Same problem as mentioned before - I moved my player & plugged it back in & I get the same error message - no radio, no cd player, no ANYTHING.
  • 189 Answers
SOURCE: I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Posted on Sep 01, 2009
SOURCE: F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Posted on Mar 21, 2008
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Posted on Aug 26, 2009
SOURCE: F61 code error
I had this problem! Panasonic 5CD Hi Fi. I opened the case to get a look at the circuits and noticed a covering of dust on the components. I took the hoover to it and an initial inspection could find no glaring problems, such as burnt PCB! I decided to power-up and to my joy the machine whizzed into life. Problem solved!!!!!!!! BTW, this unit is at aprox 10 years old and still goin great!
Posted on Oct 09, 2009
Sa-ak87 f-61, just a short ic-204,then displayed f-61
F61 is a faulty amp IC - IC needs to be replaced
Jul 28, 2014 | Audio Players & Recorders
Panasonic cd stereo system sa-ak87
F61 is a faulty amp IC - IC need to be replaced
Jul 28, 2014 | Panasonic Audio Players & Recorders
How to fix a f61 error on my mini streo
could be the amp, also check and make sure the fan is not clogged. If the fan cannot turn, it will give that error also
May 20, 2014 | Panasonic Sa-bt228 / Sc-bt228 Home Theater...
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
ยท Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
I HAVE A PANASONIC CD STEREO SYSTEM AND THE DISPLAY SHOW: F61; WHATS THE MEANING???
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
Pls rate my help.
Jan 17, 2011 | Audio Players & Recorders
What does f61 mean?
Pls rate my help.
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
Hi, my Panasonic saak-600 had the f61 problem , I change the ic stk 470-090 and the f61 dissapeared but when i turn off the system it automatically turn on after few seconde without turning on by...
seems the system is fine and what you see is display demo of the system.
while the system is on standby or even if it is on keep pressing the display button
until "no display" is displayed on the screen.
Nov 17, 2010 | Panasonic SC-AK600 CD Shelf System
While i turn on my home cinema the screen is showing F61 and automatically turn it self off
The F61 message is the Panasonic equivalent to "protect". See the link below for an explanation of protect mode. Specific to your system, there is an amplifier IC that has likely failed. Depending upon the model, this IC can cost between $75 and $100. Please post the model and I'll provide the part number and cost.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 15, 2010 | Panasonic Home Theater System System
356 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
