Question about Intel Motherboard
DX38BT don't boot after a recovery BIOS
I removed jumper and I did a recovery with the BIOS v1478, all ok on screen old version replaced by new etc., after computer ask me to reboot, and when I reboot the computer, I see the CDROM flash and 5 sec. after the computer reboot and I get nothing after. I suspect, the recovery method erase the old BIOS and didn't write the new, I used this method to upgrade the BIOS because the express method return always the old version after I executed that.
-CMOS battery ok 3.09 Volts
- file .BIO always on the CDROM.
Thanks,
  • 1 more comment
  • Ben1234 Mar 07, 2008
    I already read this procedure, and I always obtain the same thing.
    I lost the communication on the chat when I click on the link in your answer.
    Thanks you for yours comments.
  • 796 Answers
Hello ...you there....
what happened???why did the chat close??
Posted on Mar 07, 2008
  • 2 more comments
  • isaac johny
    isaac johny Mar 07, 2008
    just visit this site.....you have the troubleshooting procedure.....
    just follow this ,,,,,you should be able to retrace back
    http://www.intel.com/support/motherboard...
    thankyou...
    regards,.
    johnychel..
  • isaac johny
    ok ok ...that i dint kno.....
  • isaac johny
    ben - actually the bios is chip like thing...
    its just a matter of few microseconds that takes to flash the chip and recode it with new codes..
    when you are updating the information is stored in the RAM...
    usually when we restart the ram stores nothin...but during this time
    its different ...the RAM stores the info that needs to be burned in the bios chip..
    **NOTE: there should be no voltage fluctuation during this process...(do you have it there)
    in the new board (from 2005-till date) there are dual bios..one for back-up
  • isaac johny
    if any thing goes wrong it should troubleshoot it....
    in the older boards the chip is directly embedded on to the board ...so no choice of replacing it....you have to take it to trash.
    but as you said it was a new one ..you may have an option of replacing the chip if the provision is there on your board.....
    so take it to a tech...i wish it dont go to trash....
    thankyou for responding here....
    goodluck...
Bios password for motion computer le1600
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: biospasswordrecovery. com
May 17, 2011 | Motion Computing AP42332 LE1600 Notebook
Forgot bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Apr 26, 2011 | Gateway MT6451 Notebook
Bios boot password on a Toshiba c655-s5049
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
Feb 25, 2011 | Toshiba Computers & Internet
How to remove bios password in toshiba satellite A305-s6905 laptop? i tried removing the battery,but it didnt work... it asked me for a JO pin,which i was unable to find.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don’t have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
Jul 20, 2010 | Toshiba Computers & Internet
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
Oct 16, 2009 | HP Smart Buy Notebook
How do i reset bios password on a used dell 710m inspiron?
For you to reset the bios all you need to do is to take it out, but before you do that you'll need to power off your laptop.
Regards
Oct 13, 2009 | Dell Inspiron 710m Notebook
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
Reset cmos password for compaq nc6400
Assuming you can get to the CMOS button cell battery, remove all power, pull the button cell out for about a minute, then put it back. The next boot-up should load right to setup, or to an error screen telling that CMOS is corrupt and to run setup.
Sep 13, 2008 | Computers & Internet
T60 after Bios Update to Ver. 2.22 no Video
I do not know if this will work
1)open case
2) check motherboard for word which will say reset bios or words to that effect nearby will be a small 2 or 3 pin connector with the 2 pin remove the jumper from 1 pin and fit over both reboot and turn off straight away refit jumper back over 1 pin and reboot see what happen it may work
with 3 pin setup jumper will already be over 2 pin remove and fit over middle and the other pin remove reboot etc
Usually a failed bios update is more often than not fatal
hope this works for you if it does post favorable rating thanks
Jul 29, 2008 | IBM (10l1433) (  10L1433)...
Acer t180 bios set up
hmm you might need to flash the bios or reset the bios follow these instructions.
TO RESET BIOS
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
THATS IT BIOS RESET
Jan 10, 2008 | Acer Aspire™ T180 PC Desktop
Intel Motherboard Logo
356 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
