Question about Sony VAIO PCG-K35 Notebook
Laptop WILL NOT BOOT
We bought this laptop on an online auction a few months back. This week, we have had trouble connecting to our own wireless network (but could connect to the neighbors??) It hasn't been able to operate without being connected to an outlet for about a month. We have it plugged in (and have tried other outlets) however, when you push the power button, NOTHING happens. No fan, lights, anything. Can anyone offer a solution?
  • anamanda82 Mar 07, 2008
    Thanks! The laptop booted. Working on the wireless thing still, but the main problem is solved! :)
    Brigadier General:
  • 6,966 Answers
You seem to have two (2) problems:
1. wireless connection;
2. powering up.
On powering up, pls try:
a. charge the batteries at least overnight;
b. run the laptop with the AC adapter only and the battery removed;
c. do "b" but delay powering on the laptop for a couple of minutes.
On the wireless, pls try:
i. determine if a WEP or WPA security key is being used;
ii. check your router configurations;
iii. do a reset of your router (this would of course would set the router to default/factory values. This would be a last recourse since it is possible you will loose all Internet connectivity. Better to save your router configurations or copy them down somewhere.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 07, 2008
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Wireless connection
I had sortof the same problem with my hpdv8000 pavilion laptop..I ended up calling the phone company that I have my DSL with and trouble shooting with them the connection. I had to get rid of one connection and start a whole new one. Until it recognized the new connection. If you call HP they will charge you $9.95 to trouble shoot your computer. Both together were really helpful in getting my computer back up and running. I also had to add the drivers back in. The disc was bought from HP My computer crashes regularly..I believe that I got a lemon....Hope this helps..The info is online under HP.com
Apr 04, 2009 | HP Pavilion dv6000z PC Notebook
How do I reset paswrd for DL524 router so my laptop can connect
- Press and hold the reset pinhole at the back of router for 10 seconds with a paper clip.
Mar 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
No wireless signal
Most home router has an IP address of 192.168.1.1 or 192.168.2.1. If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
Acer Extenza 4620Z wireless connnectivity
Try letting windows manage your laptop wireless connection.  If you are using a third party sw to connect to the internet remove it and ask windows to manage your wireless connection.  Also verify that the router power cable is connected directly to the outlet and not an outlet splitter or surge protector.  Make sure your built in wireless is working and connected properly and test it than.
May 25, 2008 | Computers & Internet
Games and videos
check the internet speed first if it is ok then scan your pc with good anti viruse software
Apr 25, 2008 | HP Pavilion dv6000z Notebook
No signal to my laptop
try to restore the laptop that doesnt work by going to start accessories system tools system restore then restore it a few weeks back try that
Dec 12, 2007 | Linksys Dual-Band Wireless A+G Broadband...
Sony VAIO PCG-K35 Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
