I purchased a sound blaster X-Fi extreme audio notebook card, installed iti into my XPS M1730 Dell laptop computer amd I can not get any sound, AT ALL. Please help me to be able to get a 5.1 surround sound from the speakers that are hooked to my computer. Thank you. Lynn Evans
    Genius:
  • 1,226 Answers
Hello!
im affraid to answer your question because in most cases you will rate me " thanks for trying" it hurt me but it's ok because i want to help you.
First install the driver of your "sound blaster X-Fi extreme audio notebook card" the Utility cd is enclosed in it. after that Hook your speaker to the output of the newly installed card. and then go to control panel , double click the "sounds and audio devices" and then in the "audio tab" and in sound playbak. select the device according to your sound card.
You can adjust some setting there and click ok.
may this solve your problem.
best regards,melnavz
Posted on Mar 07, 2008
  • Emelio Navaja
    Emelio Navaja Mar 07, 2008
    Did you do my instructions please tell me. I guess the problem is in your speaker. please try another speaker. or fix connection towards your speaker.
  • Emelio Navaja
    Emelio Navaja Mar 08, 2008
    I found that you post same problemm ..Please take me a picture
    of your system like this,
    and also this
I couldnt use my mirco phone and make calls it shows cant detect ur sound card bt my speakers work wat shud i do my model is dell xps m1730
Go to the Dell website and make sure the drivers are installed for your laptop. There is a support page where you can enter the type of computer you have. Do that and it will bring you to a page of drivers. Look for the drivers for audio and microphone and save them to your computer. Then install. Hope this helps.
Mar 08, 2011 | Dell Computers & Internet
In my dell xps L501x ethernet cable is shown unplugeed even when it's plugged in. The cable which i m using works fine on my desktop which i connect to my adsl2+ mt882 modem through this cable. Cable also...
1. laptops USB port is not recognized by the router .
2. This could be due to the usb hub drivers for this unit not being installed on the laptop.
3. check your "device manager" to see if you have all the usb hub driver installed.
4. Also check your router manual for the usb setup for a laptop connection.
Feb 20, 2011 | Skque Ethernet Cable Cat5e RJ45 White 30...
I have a m1730 i purchased 2 years ago,and it is now out of warranty.it recently would not boot up properly and would only show a black screen and the cursor.i performed a full hardware diagnostics test...
Try to boot your computer first to safemode and from there, at least you will be able to back up all your files, then reinstall the whole operating system using the recovery disc that came with the computer, do a clean install by booting from the disc itself.
Hope this will help...Please rate...
Jan 20, 2011 | Dell XPS M1730 Notebook
I don't know how to use the scroll areas to the Right and Bottom of the Touchpad on my Dell XPS M1730
There is a software that comes preloaded with dell called Synaptics Pointing Software .See to that it is installed.From the software enable the required scrolling mode.by moving your finger up and down slightly pressed along the right most areas of the touch pad allows vertical scrolling while moving the finger horizontally at the bottom side of the touch pad allows horizontal scrolling.Also see to that the synaptics software is enabled at startup
Sep 29, 2009 | Dell XPS M1730 Notebook
Multimedia audio controller exclamation sign
try this driver
http://www.drivershq.com/Drivers/VistaDevices/DELL-Audio-Realtek-ALC850-AC97-AUDIO-Driver/4342/Drivers.aspx
or
http://drivers.softpedia.com/progDownload/Dell-XPS-600-Audio-Driver-Download-40848.html
or try all these dell audio drivers from here
http://www.drivershq.com/VistaDrivers.aspx
or buy a vista compatible sound card
Feb 24, 2009 | Dell OptiPlex GX270 PC Desktop
Sound card installed, still no sound
Set your default audio device in Control Panel - Sound. Also try disabling the onboard audio on your laptop in the bios menu. Make sure you have the correct drivers for your operating system. - Try to include as much information as possible in your posts to help diagnose the problem.
Mar 08, 2008 | Creative Labs Sound Blaster Live! 5.1...
43 people viewed this question
 Grubhead
Grubhead
