Question about Kitchen Ranges
Where can I find the part I need?
I have a Magic Chef oven mounted in the wall and it just completely went out. I had an electrician come and check it out he said "The oven is getting electricity but the some type of board behind the clock which all the wires hook to has gone out." I wanted to know your opinion.
  • 833 Answers
A complete failure of the oven could be caused by several things. If the unit has a master control, it could be defective or have a burned over connector in that area or any other within the unit. If you are unfamiliar with electric circuits, get a repair person. If you decide to open the unit and do a little eyeball work (with the power off) you may find your answer. Usually, there is visual indication of failures of this kind that are easy to spot.
Posted on Mar 07, 2008
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
Magic Chef kitchen range needs oven door hinges replaced
slide unit out they should be on both sides of the unit
Oct 30, 2009 | Kitchen Ranges
Bought a magic chef over under the counter wall mount in 7 2007. i have had problems with it since i bought it. call magic chef and the said that there is a built in feature to keep it from over heating. I...
I'd say your magnetron is failing.
The normal parts and labor warranty is probably one year, with a few years extra for the magnetron.
Your owner's manual will have that info. You can download owner's manuals for many Magic Chef models here.
Jan 01, 2009 | Microwave Ovens
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Magic Chef Over the Range, MicroOven, model MCO153UBF
I tried the usual things, then checked the outlet in the cupboard where the unit is plugged in.....It was okay, but then I noticed a separate electrical cable going into the wall at the outlet. I went to the breaker box downstairs, found a breaker marked "Microwave Oven", flicked it off and on and away the microwave oven went....It is now okay. I guess the thermostat had turned everything off when it became too hot....
anyway all okay now....thx Janet
Jul 22, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
