Question about Dryers
Whirlpool xxxxxxxxxxxx
  • 55 Answers
Yyyyyyyyyyy
Posted on Mar 10, 2008
I am receiving an error code 5,145,61 on my canon pixma mx870 when i try to scan
In my case all I had to do was fire up the MP Navigator software and open the preferences at top right. From there, you'll find a "product name" dropdown menu. Mine had the incorrect MAC address chosen (denoted by Network:XXXXXXXXXXXX") and once I chose the right one it started printing just fine. There are only 2 options here so if it doesn't work with one try the other.
Mar 29, 2012 | Canon PIXMA MX870 Wireless Office...
Brother DPC- 115C
It sounds like you need to update the head property...that's usually what the maintenance 7X is. These are some complicated instructions. Try to go through them and post back with a detailed description of where you get stuck (sorry, I don't have the graphics except via email) :
[ 2 ] To Update the head property information stored in the EEPROM on the main PCB:
For the MFC210C U.S.A./Canadian models, skip steps (1) through (3) below.
(1) Make sure that the machine's power cord is unplugged from an electrical outlet.
If the machine is connected to a PC, unplug the USB cable.
(2) Switch on the PC.
(3) Plug the machine's power cord into an electrical outlet.
(4) Press the Menu/Set and Black Start (Mono Start) keys. Next press the key four times to
make the machine enter the maintenance mode.
TIP: Models equipped with numerical keypads can enter the maintenance mode in the same
way as conventional models; that is, by pressing the Menu/Set, *, 2, 8, 6 and 4 keys in this
sequence.
(5) Connect the machine to the PC using the USB cable.
(6) On the PC, run the ID/head property setup utility (BrUsbsn.exe) in the folder created. The
following window appears.
(7) On the Model menu, click BH3.
6-9 Confidential
(8) In Port, select the port number assigned to the BHL2-Maintenance Printer.
To confirm the port number, follow the instructions below.
Click Start | Settings | Printers.
The Printers window appears as shown below.
Right-click the BHL2-Maintenance Printer icon.
Click Properties.
6-10 Confidential
The BHL2-Maintenance Printer Properties window appears as shown below.
Click the Ports tab.
The port number assigned to the Brother BHL2-Maitenance Printer, USB010 in this example,
is one that has been selected in Port on the BrUsbSn screen (page 6-8).
(9) In the Head Info. box on the BrUsbSn screen (page 6-8), type 12 digits (e.g., 776601D00009)
out of the 13-digit property code (enclosed with asterisks, e.g., *J776601D00009*) which is
printed on the bar code label attached to the head/carriage unit. Click the OK button.
(10) To check that the entered head property is correct (using Function code 68 in Chapter 8,
Section 8.5.16.):
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the 6 and 8 keys in this order. Then press the 2, 5, 8, 0 keys in this order.
DCP315CN/310CN/120C/115C/117C/110C
Enter 6, 8, 2, 5, 8, and 0 by using the and Set keys.*
(*To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the Set key. Repeat this operation for each
numerical code.)
The LCD shows the current head property information (12-digit code) stored in the EEPROM
on the main PCB.
(11) Check that the character string entered in step (9) is displayed in "XXXXXXXXXXXX."
If it is OK, press the Stop/Exit key.
If something other than that is displayed in XXXXXXXXXXXX, check the connection
between the PC and machine and go back to step (6).
Nov 03, 2007 | Brother DCP-110C All-In-One InkJet Printer
Tip
How to fix your PS3 when it's frozen at startup
1.The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
2.Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
3.Time to enter Safe Mode.Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
4.Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
5.Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
6.Select option number 3, (Restore File System). Then select yes to perform step.
7.You will then see this screen. "The hard disk's file system is corrupt and will be restored."
8.First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
on Apr 02, 2010 | Video Game Consoles & Games
Need default credentials for AT&T Wireless Router Model 6850G108Mbps
if it is a 2wire
look on the bottom there wil be three rows of numbers
xxxxxxxxxxxx
>xxxxxxxxxxx xxxxxxxxxxxx
the middle row should be 10 digits this is the passkey
to access the internet through at&t dsl login is your email address with att/sbc pw is the one for that acount.
Nov 18, 2010 | AT&T 6850G Router (ALL07735)
The words and screen got big on my laptop after it got stuck
go for a system restore in your OS or reset the monitor settings
Jan 21, 2010 | ViewSonic E70f 17" CRT Monitor
I need to reset the password
reset the router to default settings by pressing on the reset button for ten seconds. (usually located at the back of the unit)
May 12, 2009 | D-Link DFL 500 (DFL-500) Firewall
My yahoo messenger won't show any messages on the IM window. I can see what i am typing but not when i've sent it already. I can't also see the messages sent for me. I've already reinstall different...
Okay, here you go - Try this…:
Go to Start - Run - regsvr32 jscript.dll - OK
and then…
Start - Run - regsvr32 vbscript.dll - OK
It should work.
If you have any problems… Email me or leave me an offline message on brosibro_4real@yahoo.com
Dec 23, 2008 | Yahoo Messenger
Adf doesn't feed
Did you check the sensor in the ADF? there has to be a lever that moves when inserting a paper in ADF to let it know paper is present. is it stuck? it should have a spring action, so it returns to its positiion when paper is no longer there.
Aug 28, 2008 | Office Equipment & Supplies
Tyrecontrol inactive ???
RDC (Reifen Druck Control)
You have a button next to [DSC] that say [RDC], hold that button until the display is 100% filled eith "XXXXXXXXXXXX" and after that it will say "Tire Pressure Set". Or check in your manual for details abouat RDC.
Hope this helps, good luck!
Jun 24, 2008 | 2000 BMW 7 Series
Program!!
Here is a procedure (pasted below) which a Beta tester of CounterSpy developed having to remove and re-install various versions and running into the same problem you described. I would suggest reading through the discussion thread (CLICK HERE) before proceeding.
Hope this will FixYa!!!
____________________
Manual Uninstallation of CounterSpy 2.x
1.Open Task Manager and be sure none of these three are listed
a) SBCSSvc.exe (CP service)
b) SBCSTray.exe (tray icon)
CounterSpy.exe (CS main app)
If any are listed click "End Process"
2. Be sure the CS directory is gone. The standard location is C:\Program Files\Sunbelt Software\CounterSpy
3. Remove additional folders that may be located at these three places:
a) C:\Documents and Settings\All Users\Application\Data\Sunbelt Software
b) C:\Documents and Settings\user\Local Settings\Application Data\Sunbelt Software
c) C:\Documents and Settings\user\Application Data\Sunbelt Software
4. Run the Windows Installer Cleanup Utility. If anything is listed for Sunbelt CounterSpy, select and hit "remove".
5. Look in C:\Windows\Downloaded Installations and
C:\Program Files\Downloaded Installations
you should see one or more sub-folders with names like
{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} where the X's are random numbers. In each sub-folder will be an .msi file. Right click the .msi file and select properties. Look in the summary tab for indications that the .msi is an installer for Sunbelt CounterSpy. Delete the sub-folder, the one with all the numbers (do not delete the \Download directory folder)
6. Look in C:\Windows\Installer directory where you will find .msi files. Again, right-click each .msi and select properties. If any .msi files are Sunbelt CounterSpy, delete only those .msi files.
7. Look in C:\
if you have any {XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX} delete those folders.
8. Open Computer Management console utility (Control Panel-->Admin. Tools-->Computer Management) and select the Device Manager then click on View and select "Show hidden devices" . Expand the Non Plug and Play Drivers tree and scroll down until you find the SBHR device driver. Right-click on it and select uninstall.
The console will prompt you to reboot. Do so. If you don't find any SBHR device driver, there is no need to reboot.
9. You need to download a zip file at the bottom of my post. Follow the directions to be sure it is clean before you use it.
10. Check C:\Windows\System32 for the following 6 files and remove any if they are present:
a) SBAPIFS.sys
b) SBBD.exe
c) SBProt.sys
d) SBRC.dat
e) SBFC.dat
f) eSellerateEngine.dll
I also had a file SBProt.bak and asked if it was safe to remove; it was.
11. Check C:\Windows\System32\Drivers for the following three files and remove if any are present:
a) SBTEDrv.sys
b) SBHR.sys
c) SBAPIFS.sys
12. Last, if you have any Sunbelt CounterSpy desktop, tray or start menu icons remove them and reboot.
Jan 05, 2008 | Computers & Internet
Dryers Logo
1,006 people viewed this question
Top Dryers Experts
