Question about Microwave Ovens
Exploding microwave sounds - No Lights, No Fan, but Heats Okay
My wife put something in it 3 days ago and started to turn on the fan and light, when POP!!! (and the appropriate circuit breaker tripping did occur on its 20-amp, dedicated circuit). When it happened it something seemed to explode on the microwave's underside. It still heats just fine, but has no fan or lights working underneath anymore. Any ideas how this might happen and what to do? I wondered about grease buildup and a shorting out on an internal circuit board or something.
Okay experts give it your best shot! ALL IDEAS APPRECIATED!!
Ken with no Light (and no Fans).
  • Anonymous Jan 10, 2009
    Our microwave cooks/heats but it is very quite, the fan isn't coming on I guess.
  • Microwave Ovens Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 07, 2008
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
Micreowave does not heat items. Turntable, fan, and interior lights all work. Sound while running changes after about 3-5 seconds.
The magnetron has more than likely failed, "heats food" but also! the high voltage capacitor and diode can be a source of trouble, chances are repairs will exceed the cost of a new microwave oven.
Mar 26, 2011 | GE JVM1660 Microwave Oven
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
MICROWAVE DOESN'T WORK
32 years from a microwave!! Wow! Time for new. No parts available anymore. The smithsonian may be interested.
Oct 02, 2017 | Montgomery Ward Microwave Ovens
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Lights quit
Jan 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
