Question about Sony CDX-S2000 CD Player
Connecting To Auto Harness
I need to identify the male connection pins on the back of the unit so I can connect to the auto harness.
    Brigadier General:
  • 6,966 Answers
Most Sony head units follow the ISO standards in its wiring and connector pinouts.
A Sony CDX-S2000 would be using the below listed wiring:
Yellow - +12V Constant Power (such as the + terminal of your battery)
Red - +12V Switched Power (such as the ACC of the IGN switch)
Blue - Power Antenna
Blue/White - External Power Amp Turn-on trigger
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
In some models, Sony would have several versions of the connectors depending on the region the unit was intended for use, 10. 16 and 18 pins. The connector (loom) would have to match what your version has. They are readily available from most auto stereo stores and on line. You can try here or here .
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 07, 2008
Thanks a lot. You've been very helpful. AL2J9k
Posted on Mar 09, 2008
Wiring
What model of car is it you should be able to buy a harness to connect your new unit to the cars existing harness , if not you need to identify the wiring with a Multimeter dc setting to find your permanent 12 v and switched 12 volt and ohms to identify the existing speakers earth use your diode test tone to find the earth wire fit terminal blocks for connecting or solder and use shrink tubing if your not sure get an engineer to do this for you it doesn't take long to do and will not cost much if you wire wrong however it could cost you loads.
Apr 21, 2014 | Kenwood DDX370 Double-DIN In-Dash DVD/CD...
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
My LG washer keeps displaying LE error and shuts down. What is wrong with it?
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
Nov 20, 2009 | LG WM-2277HW Front Load Washer
Getting Le error code and washer stops
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in thsi case, the motor will need to be replaced.
Nov 18, 2009 | LG WM-2277HW Front Load Washer
My lg tromm wm1812cw washing machine is displaying LE on the screen what does that mean. it stops working when it is on the screen
HI, this error code is referring to a serious motor issue(fault). This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
Oct 26, 2009 | Washing Machines
Machine starts cycle shortly into the cycle stops LE shows in win
Oct 16, 2009 | LG Washing Machines
Need to replace the original radio on a 1999 Ford Ranger XLT (F87F-19B132-AB) and cannot identify pin connections to install a pioneer DEH-1100MP. . Need the wiring diagram for the harness connection to...
buy a adapter from local car audio store if not look in a haynes book they should have one just sitting around local auto parts store take a pic of it if u dont want to buy or write it down
Oct 03, 2009 | Pioneer Car Audio & Video
I own a lg washer le has poped up on dig. screen tub will not spin ...
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced, as well as the sensor
Aug 18, 2009 | LG Washing Machines
Cannot find wiring harness
HEY THERE. I'M HAVING A SIMILIAR PROBLEM. I CAN'T GET A REMOTE. THE NUMBER FOR THE MANUFACTURER IS
(323)-588-2999. I HOPE YOU HAVE BETTER LUCK THAN I DID.
ALLEN
Aug 13, 2006 | MT&V (MTV-AUTO) 6.5" TFT In-Dash Color TV...
Sony CDX-S2000 CD Player Logo
314 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
