Question about Onkyo Audio Players & Recorders
Bought a onkyo cp-1200a turntable wandering if i can get parts for the tone arm such as screws that hold stylus in place
  • 3 Answers
SOURCE: technics mk2 tone arm replacement
once you soldered to circuit board place - this might help Advanced Tonearm stuff Tightening the suspension on your tonearm Some TT's have tonearms which seem to be loose. If you grab the tonearm and pull it gently back and forth and it seems loose you can tighten it. It shouldn't move at all. A loose suspension can severely affect it's performance - from jumping needles to binding. It's pretty easy to tighten the suspension. You'll need a small flat screwdriver and a large one. Use the large one to loosen the outer locking screw on the top of the pivot point. Now use the smaller screwdriver to loosen up the smaller screw. Put a drop of oil where the bearings are (under that top support on the other end of the adjustment screw) so that it doesn't bind. Now tighten the small screw slowly until it just contacts the bearings. Adjust the tightness so the tonearm doesn't wiggle if you pull on it but leave it loose enough for the tonearm to pivot freely without binding. Adjust carefully and don't overtighten otherwise the bearings will be damaged! When done, tighten up the locking screw. Tightening up the headshell locking ring Have you put on your headshell, twisted that knurled tightener at the end of the tonearm as tight as possible and have found that the headshell still moves around? What will happen is that the headshell won't sit parallel to the record but may be tilted as a result of twisting of the headshell. This usually occurs when you change headshells a lot or if you've had your turntable for a while, and can contribute to needle jumping so here's what you do to fix it. First read 3.2 on base disassembly. Remove the rubber base. There will be this big piece of hard black plastic covering almost everything. You'll need to remove it. To remove the tonearm assembly look for three screws (all formerly under that black plastic) and unscrew them. Be careful not to drop the tonearm when you remove that last screw! Now, remove the tonearm assembly from the rest of the 1200, and look at the bottom of the tonearm where the headshell is put in. There will be two tiny philips screws there. Get a jewelers screwdriver of the CORRECT size and tighten those up. Put the headshell on and try wiggling it to make sure everything is right. Now put your tonearm back on and close everything back up. hope this helps peace DJ Nyce
Posted on Jul 25, 2007
SOURCE: Philips 777 stylus force adjustment
LM15 has an elliptical stylus so 1,5 - 1,8g should be sufficient, and also dial the same number on the anti skate for elliptical stylus and go for it
Posted on May 26, 2008
  • 4234 Answers
SOURCE: i balanced my tonearms correctly.
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Posted on Jul 21, 2008
  • 33 Answers
SOURCE: Tone Arm
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Posted on Aug 14, 2008
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
I have a realistic clarinette 120 turntable . How do I replace the needle?
Most are held in place by 2 small screws, remove them and carefully unplug the cartridge from the tone arm, reverse to install new one, then check the balance the tone arm and set to correct pressure..
Dec 23, 2016 | Audio Players & Recorders
My awa turntable with cassette, cd player and recorder (e 6906) has a problem. At the end of the tone arm, the part that holds the stylus is on an angle of about 10 to 20 degrees. The stylus is not...
This model uses a ceramic cartridge. Sometimes the stylus holding part can become damaged. It should be possible to get a new cartridge and stylus for the unit. It looks as it will either screw or just clip into the headshell. Either way look around for a replacement cartridge. If it has a number on the cartridge quote that. Remember it's a ceramic type - not magnetic.
Jan 02, 2015 | Audio Players & Recorders
How do I change a stylus on a record player?
Typically, the procedure is to remove the small screws holding the stylus to the tone arm. The stylus should easily detach from the connector in the tone arm.
Aug 23, 2014 | Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Automatic turntable adjustments
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Mar 28, 2014 | Audio Players & Recorders
Have stylus & headshell.need to attatch to tone arm.what other part do I need?
sounds like your missing the cartridge......the cartridge screws to the head shell, & has 4 wires connected to it...blue / red / green / white.
then the stylus,which is the needle, attaches to the cartridge.
then the hole thing connects to the tone arm, with the head shell.
Oct 08, 2013 | Audio Players & Recorders
How do you take the plastic clip off that hold the tone arm
Well be very carefull, since they breal soooo easily. You can get if bu unscrewing the imbuscat the side and the internal you desolder your tonearm wires and with some effort you can pull out the pivot after unscrewing the the height adjustment screw at the the side. They are crappy things and i just glue them together woth some thin bare thin wire to keep it in place, after that i use some kevlar/carbon fibre with the right glue, but not a lot of glue holds on it.... annoying part.
Jun 18, 2012 | Vestax PDX-2000MKII PRO Turntable
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
My turntable keeps skiping for no reason, no matter the record. i also made sure the turntable was level. the turntable is a vestax 2000mkII
What is the weight on the stylus? Flip the protective shield down to protect the stylus if available. Tare the tone arm (adjust the counterweight on the back of the arm until the arm floats perfectly level), then hold the counterweight and turn the dial markings to read zero. If you cannot find the recommended mass for the stylus you can use the average weight of 3g. Verify your tone arm is still floating in the center and the arm is perfectly level. Turn the counterweight until the dial indicates the specified weight of the cartridge manufacture specification sheet or you can set it for 3g if you do not have the specification sheet.
Nov 23, 2009 | Vestax PDX-2000MKII PRO Turntable
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
537 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
