Mitsubishi TV hand me down
Got a Mitsubishi CS-27XM1 TV from a friend who recently upgraded. First off, the remote does not work. Batteries were replaced and checked internals for bad contacts etc. Not sure how to check if IR is bad. Got a universal Remote. It will power on off and enter some setup functions which are visible on the screen. I only have an coax antenna for reception and it works fine with my other TV. I can get the audio, switch channels but I have no picture. Mostly black but occasionally odd shaped blue things that buzz across the screen. I get no static at all when the coax cable is disconnected. I have no manual and worse, no money to buy one. Lastly, the product sticker on the back says it's a CS-27XM1. I peeled it off and underneath the TV casing was stamped with CS-2723R. Things that make you go hmmm. Any thoughts would be appreciated!
  • Holden94 Mar 07, 2008
    bobbyJ,
    Is this an easy fix for someone with your experience? Not having Diagnostic tools needed for #1 is #2 reasonably straight forward if I had a schematic? Could you point to schematic for this? Thanks for your quick reply.
  • Edward
    Edward May 11, 2010
    Anyone have a broken PIP board they want to sell?
    Sergeant:
  • 395 Answers
The problem you have is the video goes thru the pip board first and the pip board has a problem this is a known problem. the pip board has some capacitors that leak on the board. the model you mention is CS-27MX1 not XM1 but anyway the back casing was made for several sets of that size. so the pip is the problem and the bulletin is as follows;
1. NO MAIN VIDEO,THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB.THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PT#181P504090. 2. NO MAIN OR PIP VIDEO, CHECK CHECK C7014, 47 UFD 35V ON THE PIP PCB. PART # 181P502060 3. CHECK FOR 7.2V DC ON THE BASE OF Q7003,IF LOW OR MISSING.CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PT#103P401050 you can by pass this by removing the pip board and jumping the VP connector pins 7 to 9 and 5 to 11
Posted on Mar 07, 2008
  • Robert Johnson Mar 07, 2008
    the repair of the pip board is not that easy. in most cases the electrolitic fluid corrodes the foil lands of the board so then it requires jumpers to fix the lands as well as replacing SMT type components. the easy way out is to bypass the pip board all together. this just means that the pip function no longer works. this set is rather old and new parts are no longer available. mitsubishi stoped making tube sets in 1999. the pip board is the board that is standing up and is connected to the main board by two connectors the VP conector and the VS connector. remove the board then cut the ground lead on the sheild of the pip board. on the foil side of the main board use a sheilded jumper and solder pins 7 to 9 and another wire to jumper pins 11 to 5 and your done. this is the easy way out.
I have a Mitsubishi cs-35505 tv. This model is an oldie, from '96, but still works... kind of. The remote is not really functional, even with new batteries and the internal speakers got turned off. I...
If you feel the remote is bad, you will need to find a new remote. The best option here is to find the MCM Electronics website. They will have a brand replacement. Thanks for asking and show a few hands of support!
Mar 21, 2011 | Mitsubishi CS-35405 TV
The horizonal hold is not working it rolls up and down
I understoof about your problem of Mitsubishi CS-35503* TV , I think you should change your interlace scanning frequancy by remote control t0 50Hz
if there will not effect then change your horizontal hold IC
Thank you!!
give your rate!!!
Feb 20, 2011 | Mitsubishi CS-35503 TV
Where may I buyt a Mitsubishi CS-32105 TV Remote? I have lost my remote.
Online. Just type in Mitsubishi CS-32105 TV Remote on your browser and bingo, many sales locations will appear.
Jul 24, 2009 | Mitsubishi CS-31205 TV
Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
May 09, 2008 | Mitsubishi CS-26201 TV
Same Mitsubishi as before. The CS-2657R
The cable box remote is programmable = contact your cable
provider to program to work volume on your Mits.............T.
Nov 28, 2007 | Mitsubishi CS-26201 TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
