Ruud Seer 12,UPMA036JAZ
What is my problem when heat stays on continuosly with both stats off?
  • 236 Answers
Replace your heat stats may be the contact inside is closed.
Posted on Mar 07, 2008
Will a th5000 work with a ruud dual fuel
Are you talking about a pro 5000 Thermostat??? if so then NO it will not work.With this stat you do not have a temperature lock on the heat pump. Say you don't want the heat pump to run below 25 degrees. it won't shut the heat pump. And you don't want the heat pump to run at the same time as the furnace. With the Pro 8000 3 heat and 2 cool thermostat you can lock out the heat pump at 25 degrees outside an turn the furnace on. You will have to install an outdoor thermostat hooked up to the pro 8000 it usually comes with the stat. Honeywell products.
Nov 29, 2013 | Rheem 3.5 Ton 14 Seer / Ruud 100K Btu 80%...
We have a model ubha-17j10nuca evaporator .we are installing a 12 seer condensor unit and they sent a KIT RXCTCHKM3306 TO CHANGE PISTON FEED TO A EXPANSION VALVE TO MAKE OLD 10 SEER UPGRADE TO 12 SEER ....
liquid line to inlet of txv. outlet of txv to inlet of evaporator. outlet of evaporator to suction line. does txv have a equializing line? strap bulb to outlet of evaporator, at either 11 oclock or one oclock and insulate bulb.
Apr 26, 2011 | Ruud Heating & Cooling
I have a ruud rcha 36a2g heat pump from 2004. What is the seer rating and tonnage of it? Also inscribed uhbc-17jo6nfh
The unit is a 3 ton or around 36,000 BTU
It also is around a 10 SEER could be a abit more depending on the maych up of the coil and airhandler or furnace combination...
Heatman101
Apr 15, 2010 | Ruud Matching Split Air Conditioner
Where is the reset button on a ruud 10 seer located?
There is no reset button on that unit...if it is not working it is because the contactor has failed, the t-stat is not calling for cooling, or the compressor is bad...
heatman101
Apr 07, 2010 | Ruud Matching Split Air Conditioner
High pressure cut out control module is locking out the restart of condensor, if you hit reset button, condensor will start up, changed air filter.system is a ruud 12 seer heat pump with scroll inside
You need to pull the condenser shroud and hose down the outside unit really, really well and I can't stress that enough. The pressure switch helps protect the outdoor unit. There are only two things that will cause this to trip.....dirty condenser coils and a blockage in the high side of the unit. On a Ruud, to clean it good, you have to remove the shroud.
Mar 23, 2009 | Ruud Central System Air Conditioner
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
