Question about Kitchen Ranges
Cooktop not responding . . .
I have no power to the stove.
I believe that I've somehow locked my cooktop stove.
What should I do?
It's a Kitchen Aid 5-burner glass cooktop.
Please advise.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Whats the model num???will help looking up a wire diagram or manual. look closely at all the control buttons for one thats marked with a little pic of a lock. press and hold it for 3-5 secs . . if controls locked there should be a lock lit in the display
Posted on Mar 07, 2008
Kitchen aid cooktop got wet wont ignight?
Usually Spark Switches might get shorted out or spark module went bad, but first unplug your stove and let it sit for a while (1-2 days) then try it again, if still nothing, then You will need to open up stove to check. Here is the video I made. Screws would not come off, so i had to replace almost all components on it. Hope It Helps.
May 28, 2014 | KitchenAid KFGU766VSS Cooktop
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
Replacement Griddle for Kitchen aid KGCP463KSS
If Kitchen Aid is of no help, try an appliance parts supplier
Apr 21, 2013 | KitchenAid 36 in. Architect KGCP463KSS Gas...
How do you get the GE externa series stove to fire? the gas stove will not light.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 03, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
How do I lift the top on a smooth cooktop electric stove. I believe there is something under my cooktop that should not be there.
General put screw driver between stove top and over and lift.....it just snaps on there.........abb
Oct 26, 2009 | Kitchen Ranges
KGCS1340P stove top -- I need burner drip pans. Source for parts, please?
I'll be glad to sell you one. I have the same model and am ready to replace it with a new cooktop. I have the same KGCS1340P but can't find part under the knob.
May 18, 2009 | KitchenAid Kitchen Ranges
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
"Cooktop Locked"
We found the manual. Held the button down for 3 seconds and it turned off. Felt like idiots!
Jul 19, 2008 | Kenmore 78823 Gas Kitchen Range
Kitchen Ranges Logo
268 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
