Question about KitchenAid KGRA806PSS Gas Kitchen Range
F3 E4 Err
I am seeing: F3 E4 bottom sensor open. What do I do?
  • JimCurly Mar 08, 2008
    I took all of the back panels off. I don't see any wording at all regarding P3, for instance. BTW: There was a 2 second power outage just before all of this happened.
  • JimCurly Mar 09, 2008
    Thank you for your efforts and comments. We unplugged it, waited for 15 seconds, and then plugged it back in. The error code went away. The oven now works correctly. Thank you again for your time. I will keep these comments for further reference.
    President:
  • KitchenAid Master
  • 2,651 Answers
Although i looked up by model number and couldn't find any "lower"sensor, the tech sheet does does list it as an open lower sensor,and here's an abbreviated portion of their repair, which ultimately leads to replacing the lower thermistor that i can seem to locate
Open the back panels and make sure the indicated temperature sensor is plugged in.
Check connector P3 on the power board. Make sure it is plugged in and fully seated.
If it is not, make the proper connection
Visually inspect the wires between P3 on the power board and the indicated temperature sensor. Make sure the wires are not cut or pinched. For the following sensors, the resistance value
should read:
Lower Oven Sensor Between 931 and 2869 ω.
(Approx. 1080 ω at room temp).
replace lower thermistor
Posted on Mar 07, 2008
  • Ron Coons
    Ron Coons Mar 09, 2008
    the "p3" was referring to a point on the circuit board, which on this machine is all but assessable, the sensor that it refers to as being bad is the electronic thermistor/temp sensor. located in oven cavity(top left corner sticking out maybe 3-4 inches.heres the part number i you wanna try replacing that b-4 calling a service guy 4455636. 2 screws and a plug
Frigidaire oven FSC88B-4 shows "Err F3 " message. What to do?
F3 - Open/shorted sensor (RTD probe) connection.
Check the temperature sensor and the wires and plugs between the sensor and the EOC are good, replace the temperature sensor (RTD probe). If the sensor and wiring are good, the EOC would need to be replaced.
Nov 23, 2016 | Frigidaire Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
In mid bake the oven turns off and says F3:E4
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven)
Replace Oven temperature sensor (RTD)
Sep 25, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
F3 code
F3 E0 5 Top oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E1 6 Top oven shorted Check for shorted sensor circuit, otherwise replace sensor F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E3 8 Clean range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E4 10 Bottom oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E5 15 Bottom oven sensor shorted Check for shorted sensor circuit, otherwise replace senso
Feb 24, 2010 | Whirlpool GS460 Gas Kitchen Range
Oven turning off
F3 - E4 Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
Please rate and god bless:)
Apr 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F3 E4 Err
E4 error complaint whirlpool ac
Jun 03, 2008 | Whirlpool RF262LXS Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
214 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
