my psp button select is working but it pushes itself . i cant tour the menu because it pops the select menu in the xmb! you have no psp dont you?my psp button select is working but it pushes itself . i cant tour the menu because it pops the select menu in the xmb! you have no psp dont you?
You can't post conmments that contain an email address.
How do you knw that the select button is not working?in most psp games the select button has no function even in the xmb menu there is no function for it.maybe youor select button is stil good.
Hi omar199562, Do a system restore by going to SETTINGS (farthest to the left of your main menu)-> SYSTEM SETTINGS -> RESTORE DEFAULT SETTINGS.If this does not fix the problem, you may need to open the face plate of your unit to check for any lodged -in particles or any defects associated with your PSP's HOME/START button bar.I hope the system restore fixes the problem so that you dont have to go to the hassle of dissembling your PSP.By the way, if the unit is still under warranty, it will be best for you to not do anything and let the technicians fix it for you because tinkering with your PSP may void the warranty.All the best to you my fellow PSP enthusiast.
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer
step 2 Press the home button on the PSP
step 3 Use the left and right buttons to find Settings ( select by pressing the X button )
step 4 Select USB Connection
-Your computer will notify you that a new USB device has been connected
This should show up as a new hard drive with a corresponding letter identifier
step 5 On your computer, select the correct drive letter and open PSP file system
step 6 Create a new folder and call it PSP
step 7 Go inside this new PSP folder and create another folder. Name it MUSIC
step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created
step 9 Disconnect the PSP from your computer by pressing the O button
step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC
- Select Memory Stick by pressing the X button
You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP.
http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
Press Hold Triangle Square Select Start at The Same Time and the Power Button and you should see the initial setup;and then you can recover the settings of your PSP :) ,hope it'll work ;)
the control chip under the button isnt making contact with the plastic button,, easy fix, take the cover off the psp clean the buttons with a pencil eraser and put the cover back on (without screwing it down) check for contact,,,,if it works then screw it back together if it doesnt then pop the cover off and put a small piece of tape on the select button its self to make up for the slack). Hope this helps you out..it worked for me!
I used to have the same problem. Unfortunately, this is because your PSP has become physically damaged. The music button has been permanently locked in the pressed position, and whenever you hit Home, it thinks you are releasing the Music button, which mutes the system. This specific problem I have dealt with personally. I assume the other two are similar in nature. Unfortunately, all you can do about this is to get it fixed (somehow...), by a new psp, or learn to deal with it :(
If fixing and dealing with it is not an option, why not use it as an excuse to pick up a psp go when it drops? or if the lack of UMD is a turnoff, maybe a slim (if you don't have that already)
its a coincidence, the buttons sensor just broke. I can replace it a t my store its really easy. go on ebay and look for a new sensor bar for the psp you can install yourself with a set of small phillips head screwdrivers and one flat. good luck!
Bring it back to the store where you purchased it or just all the SONY COMPANY and they will replace it. DO NOOT TELL THEM THAT YOU DROPPED YOUR PSP AND A RIVER because they will not want to fix it or replace you psp console.
in order to fix this setting you have to download a video to your psp
1. go to your video on your psp then open it
2.then press ''triangle button '' on your psp
3. browse and you should see ''audio options;
4. then press ''O'' button on psp you shoul see ''left+right'' at left lower corner on your psp
so easy..have fun
or much easy way
when listening to mp3 on your psp try pressing the button beside the left side of ''select button '' on your psp
by;marziano
