Question about Gateway FPD1760 17" LCD Monitor
Monitor is too bright
My wife updated the web root program and ever since the display on the monitor is way too bright. The computer is working fine it's just that the display is too bright. Has anyone else had this problem? Is this what happens when a monitor dies?
    Champion:
  • 220 Answers
Lcd monitors do not go overbright due to aging,they may go dim due to backlight aging.Do front panel controls work and if so what happens when you try to bring down brightness?
Some monitors have a "Recall" function which is a factory restore bringing all setting to factory value.
Try this if available.
Samir
Posted on Mar 07, 2008
Power led brightly on but no display on AOC S5G10
It is understood that your AOC monitor is not working, you had followed troubleshooting steps like connecting VGA and Power cable from monitor to computer and the monitor panel light is ON but still no display. You have tried connecting another monitor and it is working fine, so it is advised to contact AOC support to check if the monitor is under warranty and it can be replaced or repair. To help you do these, please follow the link given below:
http://us.aoc.com/aoc-technical-support/?page=contact-technical-support
GuruAid.com
May 24, 2016 | AOC Computers & Internet
Monitor brightness
Are you sure you got the Model right. I don't see that Model here... http://www.aocmonitorap.com/root/my/user_manual.php
Jul 10, 2014 | AOC Computers & Internet
Settings brightness
Hi which monitor are you using? Connect a different monitor to same system to see if that monitor works correctly with that CPU with same settings or connect your monitor with another CPU which is working properly with different monitor to pinpoint exact problem first. Any monitor if gets old will have such problem. If monitor is okay then you can check if display driver is present or not by going to See how many output connections your monitor has if it has multiple input connections like display port, HDMI, DVI, etc, you can try connecting to different ports if your CPU supports to see which connection gives what type of display.
https://youtu.be/lOT4zLqMOWQ
This video has partial information about display settings. You can right click on desktop and select properties and make it to default settings.
Dec 19, 2017 | Samsung SyncMaster P2250 22 inch LCD...
I was using my laptop and left it for a while, when i came back to it again and brought it out of sleep mode my display was distorted and every place it was a light color or white was now a bright pink. I...
It is probably your the laptop monitor since hooking up an external monitor works fine. You could try reloading or updating the driver to your laptop monitor
Jan 07, 2011 | Computers & Internet
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
Gnr ts700 Screen has gone to the Middle Of the monitor
Did the other monitor have the same problem or was it ok? If it's just the one monitor, it may be on it's way out. It is very dangerous to open a monitor and try to repair it. Don't do it yourself unless you know exactly what you are doing. Have you installed anything new in your pc? What about seeing if there is an updated driver for the monitor? The monitor's website - support page - should have a driver update. See if that works. If you recently installed a graphics program, it could be a setting there that is messing things up.
Jun 18, 2008 | Gateway FPD2275W LCD Monitor
Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Nov 06, 2007 | ViewSonic VA1703wb Monitor
Problem with display, need help finding what the problem is
I have the same problem with my monitor and it did not happen until windows update started installing a driver---before that my monitor was working fine. (It was on automatic update) I think it is because the new driver sets the monitor at 100hertz and the syncmaster works best at 60 hertz ( I think).
Since I am unable to see anything on the monitor I do not know how to reset this though. I do think if I could get it working at a lower refresh rate then it would work again---damn automatic updates anyway.
I took my puter back to an earlier date before it had upgraded but my monitor still has the line thing going on. Hope someone has some suggestions for this.
Oct 06, 2007 | Samsung SyncMaster 172N 17" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Gateway FPD1760 17" LCD Monitor Logo
118 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
