Question about Motorola Mobility RAZR V3x Cellular Phone
Display color depth
Motorola ROKR z6--the display looks like it is only showing 16 colors--kind of like Windows in Safe Mode. The phone did this on its own. I haven't been able to find any settings that would allow me to change the color depth. The rest of the phone seems to work fine. The phone was fine for the first month.
  • 24 Answers
Well then your gay
Posted on Mar 25, 2008
Forgot my unlock code on my Motorola rokr z6
When you receive your email with your unique Motorola unlocking codes, you may see there's actually more than one code as some models require more than one code to unlock them fully. However, for simplicity, we do aim to send you a single unlock code.
Example:
359810001112345 F33RHE1234 12345678 85901234 5F8D1234
The unlocking code is 3rd part in this example: 12345678.
(We may also return your IMEI number, simply ignore this, it will always be the first)
Motorola Models
1. Switch On your phone with a SIM Card not from the original network. (IE Not the network it's locked to)
2. The phone should now show the message 'Enter Special Code' or 'Enter subsidy code'
3. You can now enter the Unlocking Code provided to unlock the phone.
WARNING : If One of these messages is displayed:
- 'Contact Service Provider'
- 'Tamper Alert'
- 'Wait before enter special Code'
- 'Contact Service'
It's because too many incorrect codes have been entered. To reset this, you will need to leave the phone on displaying this error message, until it changes to 'Enter Code Special' or 'Enter subsidy code'. This can take up to 72 hours.
Note: If your phone is on a 'Three' network, you will need to enter * * 0 5 7 * to open another window to enter your code.
Dec 04, 2013 | Motorola Mobility Z6 ROKR Unlocked GSM...
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Restart at 32 bit depth color
Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System.
3. Select Advanced Tab and then go down to Startup and Recovery.
4. Settings then uncheck the Automatically Restart.
Try that and see if you can sort it out from there. Hope this helps!
May 08, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Themes for this phone
The web site for c1-01 theme
Apr 15, 2009 | Cell Phones
Motorola ROKR Z6 Camera not working Suddenly
pls, drop your phone on water then keep 1 hr in woven in 100 temp.
Dec 05, 2008 | Motorola Mobility MOTORIZR Z6tv Cellular...
I see two screens on my desktop.
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Sep 21, 2008 | ASTVision 5B 15 in.CRT Conventional...
My MotoROKR E6 display is not working. i have checked mobile with local repair center. They said display problem need to replace. Please assist how much does a display cost?
This may not be the problem with your phone, but I had the display go out on another motorola (razr) and it was the flex cable that goes from the main board to the screen. Since the ROKR doesn't have a flex cable it is less likely that is your problem but it is worth checking the cable to the LCD anyway. I know that with the RAZR, the cable is fairly loosely held in place and would be easy to knock loose if the phone was dropped.
If that is not the problem, you should be able to get a display on ebay for a lot cheaper than from Motorola. here is a current auction for an LCD: http://cgi.ebay.com/For-Motorola-Z6-Rokr-Original-LCD-Display-Screen-Tools_W0QQitemZ300242976439QQihZ020QQcategoryZ20336QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
if you can't find the LCD by itself I would recommend looking for a broken phone on ebay to swap screens with.
Jul 18, 2008 | Cell Phones
Motorola rokr z6
make sure that your BT - Bluetooth device is on,if it is on and you are still unable to rec/send then master reset the phone if that still does not work then you make need to take the phone into a service center and have it check.
Jun 15, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Motorola Mobility RAZR V3x Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
