Son hit code search= held it and erased it - we now need a code to operate our television. Can you please send me the code.
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    Need the manufacturer and model of the TV, and any other product you are trying to operate. also, the manufacturer and model of the remote control.
  • 8,596 Answers
Bought a new remote!
Posted on May 30, 2008
Posted on Mar 07, 2008
My upper case on the number 2 is not working...I need the * at * sign to send an e-mail to my son...Anything I can do without erasing this..Thanks
try holding down the alt key then type the following with alt still held down on the number pad top the right of the keyboard type 64 then release the alt and @ should appear If this doesnt work first time press number lock numlock key and try again
Mar 07, 2017 | The Computers & Internet
How do I delete top hits and Bookmarks from iPhone5??
You will need to delete your browser cache to remove top hits.
To clear the browser cache:
From the Home screen, choose Settings > Safari. Tap Clear Cache.
To delete bookmarks:
Open any webpage in Safari and then tap the bookmark icon at the bottom of the browser. Once the Bookmarks window shows, tap on the edit button at the bottom right. The bookmarks will then show a red delete icon next to them. Tap the icon to delete the bookmark.
Hope that helps!
Oct 09, 2014 | Apple iPhone 5
Pls my son mistakeing use my phone to play and it aksing me to enter my puk number on Airtel networking
If you enter the unlock PIN code incorrectly 3 times then the SIM card will block and you will need the PUK code to unlock it.
According to my searches you can get the PUK code from AirTel by following these instructions:
Send a text message with the text:
PUK<space>YourPhoneNumber
to toll free number 121
If this does not work then please call Airtel customer support and they will give you the PUK code.
Hope this helps, please rate my answer,
Chris
Mar 02, 2011 | Computers & Internet
I need the three digit code for the ge universal remote control for sylvania 6513DD please.
Hi, You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
Nov 06, 2010 | Sylvania 6513DD 13 in. TV/DVD Combo
Lost the instrucción of SONY RM-V310 how do I set the control remote to a Jensen TV ??
Code is 079
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
Jul 30, 2010 | Televison & Video
Can not sent out text messagegs, looked at center address and it appears my son erased part of the number that was in there. will this stop it from working?
hi there, yes you are right
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect now as your son has erased a part of it...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
Sep 28, 2009 | Pantech Matrix Cell Phone
Parental Control Password
Use the code 7777 to erase the current code.This will set the code back to the factory default code which is 0000.
Apr 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
How do I reset my chamberlain garage key pad, after the liftmaster repair guy erased the code? What do I push on the keypad, while holding the green liftmaster learn button? thanks
hope you have not held green button or your renotes will bew erased. Push green button for one second. Go to keypad. Enter 4 digit code and hit ENTER. Bulb on motor should blink. That's it.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
No button for code search ?
Hold The Tv Or Device To Be Programmed and hit power with it. then hit power until it turns on or off. then hit enter if you have one or hit tv/dvd/cable again. Hope This Helps
Jan 05, 2009 | Sylvania 6413TC 13" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
