Question about Proscan 32LA30Q Television
Channels will not change
When I press the up down channel button it goes back to channel 2.
  • nickd4444 Mar 10, 2008
    i do not have an auto program option on my menu. I have a 32LA25Q and i think the menu is different then from the others
    Sergeant:
  • 280 Answers
Do a auto program from the menu. If the set has lost its memory from a power loss or other situation it will loss it memory of what channels you have and unless you put the channel in from the remote it will default to ch 2
Posted on Mar 07, 2008
  • coyotedave Mar 10, 2008
    Check your menu and make sure that the selection is set to cable . Then you should have the option to search. That should put you set in the search mode and find available Chanel's. Check your owners manual for the channel set up option
How do i get a legrand 412641 to change from chanel one to chanel two
Looking at product manual, it is unclear how you toggle between channels.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
There are 4 buttons. Menu, C1-, C2+, and OK.
The menu button: looks like you press repeatedly to scroll through menu items. If you hold down more than 1 second, it goes to operating display.
To get to each channel... generally, it appears you either
.... Press Menu to scroll down to PROGRAM, then click OK, then use press menu to select Channel 1 or Channel 2, then click OK
... OR you Press Menu to scroll down to PROGRAM, then click C1 button or C2 button to select channel
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 24, 2015 | Legrand Hardware & Accessories
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
My remote won't let me channel down past a certain channel, I can type the numbers in and it will go but if I try to arrow down channels it goes about 5 channels and then starts back over where it started,...
mp_383
What channels are you able to receive? When you press the Select button on DISH remote, which light on the top of the remote lights up? The Sat button should light up when you are in satellite mode. If any other button lights up, press and release the Sat button and then try changing channels. If this doesn't work, we may need to troubleshoot with you. Please call us on 1-800-333-3474 and speak with Tech Support. I hope this helps.
Ray Calo
DISH Network
Mar 08, 2011 | DISH Network 135899 Remote Control
I do not have the original remote and have no Idea how to change to video 1 or video 2 channels
Do it with the buttons on your TV scroll down through your channels after the channels run out keep pressing channel Video 1 should appear if u you need Video 2 press the channel button again.
Aug 14, 2010 | Toshiba 32A35 32" TV
Need code for dynex television, using a nexxtech 1519000A remote.
Programming with Code Search
1. Manually turn on the device (TV or
Cable box) to be controlled.
2. Press and hold the P (Program) button
until the red indicator stays on. Release
the P button.
3. Press and release the desired mode
button (TV or Cable). The red indicator
blinks, then stays lit.
4. Press the Channel Up button repeatedly
(up to 300 times) until the device to be
controlled changes channels. If you
accidentally overshoot the desired code,
press the Channel Down button to
backtrack through the library until the
device changes channels. Pressing
Channel Up changes the direction to
forward again.
5. Press and release the Enter button to set
the code.
If the device does not have a Channel Up
button, use Power instead. If you go all the
way through the code library without
finding the correct code the indicator blinks
a few times then goes off.
Feb 05, 2010 | Dynex 24" Standard-Definition Digital TV
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Channels changing on its own, sound increasing on its own
Do you know where your remote is?I have had it where it would do that for days and then I would find my remote was wedged into my chair somewhere and when I sat down it would press a button.Either that or check the wires in the remote and TV.For the changing channels do you look at your remote when you press buttons to switch channels?There is a common button,which,when pressed,will surf through all of your tv's channels.
Jan 31, 2009 | Sony KLV-S26A10 26 in. HD-Ready LCD...
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
Proscan 32LA30Q Television Logo
88 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
