Question about Kitchen Ranges
Connection of the cable wire to the circuit block at the back of the stove
Trying to figure out how the electric cable wires fit or go ont the circuit block at the back of the stove
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
3 wires BLACK(110v), WHITE(nuetral), RED(110v). doesnt matter black or red,left or rigth so long as white is in middle..
Posted on Mar 07, 2008
I have an 84 impala and my alternator belt snapped off. Once i replaced the alternator belt, the car started and drove fine except my horn, interior lights, head lights, and tail lights don't work. I...
Circuit Breakers
Print
One device used to protect electrical components from burning out due to excessive current is a circuit breaker. Circuit breakers open and close the flow path for the electricity rapidly in order to protect the circuit if current is excessive. A circuit breaker is used on components which are more likely to draw excessive current such as the breaker found in the light switch that protects the headlight circuit. A separate 30 amp breaker mounted on the firewall or fuse block protects the power window and seat circuits, as applicable.
Fusible Links
Print
A fusible link is a protective device used in an electrical circuit and acts very much like a standard fuse. The major difference lies in that fusible links are larger and capable of conducting a higher amperage than most fuses. When the current increases beyond the rated amperage for a given link, the fusible metal of the wire link will melt, thus breaking the electrical circuit and preventing further damage to any other components or wiring. Whenever a fusible link is melted because of a short circuit, correct the cause before installing a new one. Most models have four fusible links.
REPLACING FUSIBLE LINKS
  1. Disconnect the negative battery cable, followed by the positive cable. If the link is connected to the junction block or starter solenoid, disconnect it there as well.
  2. Cut the wiring harness right behind the link connector(s) and remove.
  3. Strip the insulation off the harness wire back 1 / 2 in (12.7mm).
  4. Position the clip around the new link and wiring harness or new connector and crimp it securely. Then, solder the connection, using rosin core solder and sufficient heat to guarantee a good connection. Repeat for the remaining connection.
  5. Tape all exposed wiring with electrical tape or use a heat shrink tube, if available. Where necessary, connect the link to the junction block or started solenoid. Reconnect the positive, followed by the negative battery cables.
Oct 21, 2013 | 1984 Chevrolet Impala
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Wireing thee wire to four wire,small metal tab between ground and middle wire.?do I take it off?
If you have a 3-wire appliance and you are replacing the 3-wire cable with a 4-wire cable, yes, you _must_ remove the metal tab (bonding strap) that is connected from the white wire on the terminal block to the frame.
Connect the black, red, and white wires to the terminal block, then connect the green wire to the frame using the green screw.
Usually the bonding strap stays under the (green) screw without being connected to the terminal block so should someone need to connect it back to a 3-wire cable the bonding strap will be there.
Jan 13, 2010 | General Electric Stove/Oven/Range Chrome...
Put on the self cleaning...and some wires in the back sparked and it shut down the circuit breakers? ITs a electric tappan
Hello
Is the stove directly wired? The code says the wire coming from the breaker box should be connected to a four prong 50amp range receptacle. Then a 50amp four prong range cord from the receptacle to the range. There's a clip on the back of the stove that connects the neutral wire to the frame of the stove. It has to be removed and the green wire coming from the cord connected to a green screw on the stove to separate the neutral form the ground. Get a licensed electrician.
John
Dec 12, 2009 | Tappan TEF242 Electric Kitchen Range
Just purchased new electric stove. The old stove had been hard wired. Black, white and copper. The new stove is asking to connect red, white and black. what should i do ?
Normaly black, white, copper (ground) is a 2-wire 110 volt, black white, red, copper is a 3-wire 220volt circuit. You must have a 3-wire cicuit run from circuit breaker box to stove connector.
Apr 28, 2009 | Kitchen Ranges
Stove power is out
Turn off the power.
Remove the rear panel on the range.
Repair the broken wire at the wiring terminal.
Install a wiring strain clamp at the terminal block to prevent this from happening again.
Mar 25, 2009 | Electrolux Kitchen Ranges
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Kelvinator Stove Power Cable Connection
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Richard
Dec 23, 2007 | Stoves 1100ESIDLa Electric Kitchen Range
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
