Question about Philips HTS3400/37B System
When i push power light jus flashes and nothin powers up
When i try to turn the system on the power light just flashes and nothin happens it just keeps flashin and tickin
  • 1 more comment
  • meelous Mar 07, 2008
    how much yall gunna pay me to fix this .. cuz i already fix a few with this problem
  • FLEE75 Jun 25, 2008
    SAME PROBLEM
  • Anonymous Sep 08, 2008
    unpluged
There is a single capacitor on the main power board that has burned out. I found another site that had a great step by step with pics but now cant find the link...if you take the unit apart and look at the board where the power cord is connected...run your finger across the top of the black and silver capacitors you will find one that is slightly buldging up...that is your problem child...a new one cost a whole $1.62 at Frys...it cost me 3 bucks for the solder since I couldn't find mine...it took about 35 minutes to repair...the hardest part is flipping the board over and melting the correct solder point ....search around and see if you can find the web site I mentioned he did a great job of explaining it...his fix was for a slightly newer model but it was spot on...good luck
Posted on Oct 22, 2008
  • 4 Answers
Hey meelous, you still there?
How did you fix it? Full Wave Bridge went out?
It's always a $3 part and $100 in labor, that's why all consumer electronics are disposable. It's cheaper to throw them away and do without than to fix them.
Posted on Aug 30, 2008
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
When I press start nothing happens then "door" flashes on screen even though the door is definitely closed
have you tried push the door in harder once u have turned it on my grandads old hotpoint washer was like this and wen used to jus push the closed door a liltte and it started
Dec 03, 2011 | Hotpoint Washing Machines
The lights in the dash come on but the security light jus flashes and the car want turn over or nothin
You have a failed antitheft security system. The key is most likely the problem. That little chip tends to wear down. It could also be a few other things. Since the light is flashing, it will either be the key or ignition lock cylinder. If it wear solid, then it would be the TDM (Theft Deterrent Module) which is the brain of the security system. Try rplacing the key. if that doesnt work you have 2 choices. Replace the ignition or bypass the security. There are 2 ways to bypass your car. BOTH will work for you. Ive done it. This link will help you understand the system and guide you with pictures and those 2 other links. Any questions, comment back on THIS post. Im good with BUICKS and always willing to help. Thanks for using FixYa
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 16, 2011 | 1995 Buick Regal
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Laptop wont turn on
Does the power light flash? Try remove the battery for 5 mins with unit unplugged, then reseat the battery and try again.
Feb 21, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Laptop screen blank at start up
If it still doesn't work when you hook it up to an external monitor, assuming you did that properly, then it is your motherboard/video card.
If you have a seperate video card, I would replace that first. If you don't have a seperate video card, then you need a new motherboard.
FIRST - I would try hooking it back up to an external monitor, and making sure you switch it over to use the external as the default. otherwise you wont get picture.
Sorry... good luck.
Sep 10, 2009 | HP Pavilion dv2120us Notebook
Wont turn on
The power supply board has been defected. Replace it with a new one.
Aug 15, 2009 | Samsung LN32A330 32 in. LCD TV
I touch white screen
use the power button on top.
Jun 17, 2009 | Apple iPod touch
3 red flashing lights
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
Oct 17, 2008 | Microsoft Xbox 360 Console
Philips HTS3400/37B System Logo
984 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
