Question about Kenwood KDC-MP235 CD Player
AUX slots What si the difference between AUX 1 and AUX 2? I plugged a Y adapter into the rear of the unit, and played my ipod but there was no connection. Are those white and red plugs spaces for that Y adapter? And if so what AUX should i use?
  • aer612 Mar 07, 2008
    thanks again. So AUX 1 should be the front input, right?
  • dinix Mar 20, 2008
    i pluged my device in but have no connection of no sort.i was wonderin what mode should the radio be in to get mt mp3 player to work.
  • 46 Answers
Hello..i think that.aux in this case is an output..you can try this through connecting your amplifier to any of the aux outputs... and play a cd ,sorry..good luck ..Ron.
Posted on Mar 07, 2008
  • lars ahlsen Mar 07, 2008
    hello again...if you have a home theatre amplifier you can connect aux 1...to main..."front" input but depending on the amplifier you must know what other in/outputs you have like an bass module or satelites it's not so clear..but it's just to try what happens,just remember to keep volume off when connecting...and if you want to play your ipod via the amplifier than you can maybe use video or tape inputs of your amplifier...do not use the "phono" input..tat's for vinyl...good luck..Ron
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
Does the Kenwood KDC MP5032 have an aux input? If so, where is it?
Kenwood utilize the CD Changer plug in the back (which acts as a secondary Aux input), to operate external iPod devices.
This is done with the aid of an Adapter Lead - it has the 13-pin DIN plug on one end (plugs into the rear of your unit), and an iPod plug on the other end (plugs into your iPod).
Depending on the "Generation" of your external iPod device, you will need to buy the appropriate Kenwood adapter cable. These are: KCA-IP102, KCA-IP202 or KCA-IP302.
There may be some aftermarket (3rd party) cables that may do the same job.
Just ensure you read your Kenwood manual, as the Kenwood unit may be limited to the types of files (i.e. formats) it can read & play.
Hope this explains....
Cheers,
Dec 31, 2012 | Kenwood KDC-MP5032 CD Player
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
How can I hook up my Ipod to the radio system inexpensively
If you don't have a cassette player, you can purchase an ipod/RCA adapter cable for about $10 and plug it into your aux inputs in the rear. The cable has one end that fits into your ipod headphone plug and the other end is a white and red pair of plugs (called RCA plugs)that will plug into the rear inputs.
Jan 27, 2010 | 2006 Honda Odyssey
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Can't get iPod to play through factory sound system, pls help
u can buy a cable that splits from an audio output into the red and white cables so u can hook it up to anolog jacks
Jan 07, 2009 | 2004 Chevrolet TrailBlazer
Phase linear uv8
Assuming that your unit have a rear video/audio input, you need an adapter cable. 35mm to video/audio rca. You may find one on Ebay or RadioShack. Goodluck.
Jan 28, 2008 | Lanzar SVD26MUT Car DVD Player
Kenwood KDC-MP235 CD Player Logo
752 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
