Question about Sharp AR-C160 Color Copier
Error code When I turn on the power to my machine, call for service code:E7-10 comes up. What is that error code?
  • 62 Answers
Remove fuse 801 this will take care of problem.This is a laser problem.
Posted on Mar 07, 2008
How to solve E000001-0002 canon ir3300 error code
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Mar 03, 2018 | Canon Office Equipment & Supplies
Reset Error codes
Select copier
select clear
select ERR
press OK
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon code E000001-0002
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
CALL FOR SERVICE ERROR C440
This is fuser judgment abnormality.
usally you can just reset the code and the machine willl work.
to reset the code do the following:
1. Turn the mahine off from the main power switch (on front or side depending on the model)
2. hold down the '0' and '8' keys on the keypad and turn the machine back on.
3. when the machin starts and the startup screen is done enter 400 and press start.
4. u will see the same number twice. write this number down and keep it in case the error comes back.
5. now press the '0' key and the enter button on the display.
6. turn power off wait 5 sec and turn it back on normally.
this clears the code, if the code returns you can try repeating this but most likely you will need to call for service and give them the error code and the number you wrote down
Dec 27, 2012 | Toshiba e-Studio 350 Copier
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Jan 11, 2011 | Canon Office Equipment & Supplies
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
How do I fix this?
please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
Good Luck!!
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Error message on screen E000001-0002
Sep 21, 2007 | Canon imageRUNNER 2200
Sharp AR-C160 Color Copier Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
