Question about Sony PlayStation 2 Slimline Console
No spin and laser grinding on the rail!
My slimline ps2 cd spinner won't spin and the laser moves on the attached rail when powered up and grinds on the rail with this really loud grinding sound. What do I do?
    Problem Solver:
  • 34 Answers
Call Sony Canada as soon as possible as this could scratch and ruin your games before you know it!!!! The Help/Support Number is toll free. It is: 1-800-222-7669
Posted on Aug 29, 2008
The ps2 works fine, but when i try to play a game, it doesnt sense the cd. it doesnt even spin. anything i could do?
barely put any oil where the spinner and ps2 are connected on the top, but clean the oil off. if that doesnt work your motherboard might have chipped at where the spinner usually spins at.
Dec 09, 2009 | Sony PlayStation 2 Slimline Console
The disk do`snt spin
No Spin At All
If your spindle hub is NOT SPINNING AT ALL,
NOT EVEN 1/2 OF A TURN, it may be bad or unplugged.
A tell tale sign of it being unplugged is if you hit
eject, the laser moves down the rail, and starts
grinding because the PS2 keeps trying to move it
down the rail even though it hit the end. There's a
small switch on the spindle hub that tells the unit
to stop pushing the laser because it's reached the
end. Spindle hubs usually do not go bad by themselves,
usually either the PS2 too a bad fall and it became
bent [try spinning it by hand], or someone the cable
out and put it in too many times [or incorrectly] and
the silver contacts on the cable were detached.
Reasons for 1/2 spin:
1. A dirty laser. Try cleaning the laser and see if it helps.
If you can see crust or dust covering the laser eye, it may
not be strong enough to read anything at all. If the laser
looks clean, this is probably not the issue.
2. An unplugged laser cable. These things normally do not come
out by themselves, but if you opened the ps2 that was spinning
OK to clean the laser and/or removed the laser to clean it,
plugged it in, now it's spinning 1/2 of a turn, the laser cable
may not be in securely. If it is in securely, make sure it is
plugged into the motherboard end properly.
3. A dead laser. On models 30001, 35001, and some 30001R, this
is the most likely issue. These models are old and the original
lasers were a bit unreliable.
Dec 06, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
Disc wont spin in our play station 2 and lid is closed all the way
Their could be two things:
1. No Spin At All:
2. 1/2 spin:
Oct 31, 2009 | Sony PlayStation 2 (PS2) Console
My 50001 Ps2(Fat) is making a Grinding noise...... I know what it it doing....The laser mover motor is moving and the laser is just coming off the Gold rail.....the other 2 rails are nice and smooth and...
okay, try this. hope this helps. what you're looking for is a post by Nintendoman (kyle)(#2186); post date saturday, Dec. 31,2005 to fix that grinding noise --> mattread.com/2004/01/ps2-disc-read-error-fix also try www.powerfulguides.com/ps2 ;D
Jun 07, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 spinner wont spin
hi..this is jagdish ...i fix all ps2 problems...there can be 3 problems
1-you have a lens failure
2-if your ps2 is modified then the chip can have a problem
3-or the mechanism on which the lens moves has failed
mangal9@yahoo.com byeeeeeee
Jul 17, 2008 | Sony PlayStation 2 Slimline Console
replace the DVD/CD drive. Reasonable costs if you look online.
Mar 22, 2008 | Sony PlayStation 2 Slimline Console
Playstation 2 slimline
wat did u do to that poor machine!?! i broke something...or, theres a Lego (lol) in the track...open her up, and take a pic...send it 2 me, and ill tell ya from there..kk
ps: jedi_arts_101@yahoo.com
Feb 05, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
