Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Tv just shut off and red light is flashing
I have a grand wega kdf-55wf655 projection tv. Bought it Dec. 2004 circuit city.TV just shut off tonight and red power light is flasing 6 times and repeats over and over. could use some diagnostic help thank's Fly1
  • 2 more comments
  • fly1 Mar 07, 2008
    THANK'S FOR THE INFO.. COULD BE SHORT POSSABLE FUSE ? THINK I MIGHT TRY THAT 1ST.
  • parkanddon Mar 12, 2008
    Have the same problem had it fixed once with a $4.50 fuse that cost over $250.00 in labor and in home fix, it took the guy longer to get to the part than it did to replace it, he was done in about 30 minutes, now the tv is dead again less than a year later and after replacing the lamp also for ~$200.00 I am ready to toss this hunk of junk to the curb and buy a Vizio with ext. warranty from Sears.
    Well my repairman is on his way out again to repalce the thermal fuse again, probably get a Christmas card from him this year becoming a frequent customer. He said this should not happen twice, his tips are to make sure it is away from the wall and that it gets a good vaccuming frequently to keep dust from building up and overheating the tv. Sony would not help with the repair cost for the 2nd time for $250.00, So that will be the last Sony product I buy ever.
  • ramman65 Mar 14, 2008
    tv just shut off and red light is flashing
Have repairman look at the Thermal fuse, I am replacing my 2nd one.
Posted on Mar 12, 2008
  • 8,596 Answers
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Posted on Mar 07, 2008
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
When i turn on the tv the power light starts blinking red and it turns off
Hi I have a Sony KDF-55WF655 and I just installed a new lamp, now when I got to turn on the tv my power light flashes 5 green followed by 6 red flashes and continues to flash a series of 6 red flashes and has no pic, Any help would be great
Jul 13, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Jul 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Mar 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony tv kp-46s25
how many times does the light flash cause it might be an error code from the shut down circuit
Apr 12, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
2 yr old Sony Grand Wega KDFE55SA20
Try cleaning your air filter sounds like its a thermal problem, often its due to an obstruction in the air filter.
Jan 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
404 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
